anothercadguy Posted June 25, 2008 Share Posted June 25, 2008 Greeting to all, I am trying to built a lisp to offset a line. here's what I have: (defun c:off () (Command "_offset" "e" "yes" pause) (princ) ) the only thing with this is that I cannot find the variable where auto stores the original setting and once I exit my custom command, auto cad keeps the "erase" source as yes. Obviously I am not too familiar with lisp yet, so any help will be greatly appreciated. thanks in advance. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 25, 2008 Share Posted June 25, 2008 Please use code tags when posting lisp code. Also, you can disable smilies using the checkbox under "Miscellaneous Options" in each post. Now to the original problem. I don't think there is a variable that controls the erase option. However, you could use this line to turn off the erase feature (command "._offset" "_E" "_No" "" "_E") Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 26, 2008 Share Posted June 26, 2008 have a look at this, it's real quick and real dirty. (defun c:OFF (/ offset_dist obj_2_offset offset_side) (setvar 'cmdecho 0) (while (= offset_dist nil) (setq offset_dist (getdist "\nOffset distance: ")) );while (while (while (= obj_2_offset nil) (setq obj_2_offset (entsel (strcat "\nPick object to offset <" (rtos offset_dist) ">: "))) );while (while (= offset_side nil) (setq offset_side (getpoint "\nSide to offset on: ")) );while (command "offset" offset_dist obj_2_offset offset_side "") (command "erase" obj_2_offset "") (setq obj_2_offset nil) (setq offset_side nil) );while (princ)) Quote Link to comment Share on other sites More sharing options...
anothercadguy Posted June 26, 2008 Author Share Posted June 26, 2008 Thanks for the code and smiley info rkmcswain. I've tried your method but it wouldn't fly. the alanjt script works but it loops towards the end, Once you enter the distance and offset your line, the commands stays put and won't accept any other distance. thanks for your reply s Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 26, 2008 Share Posted June 26, 2008 I've tried your method but it wouldn't fly. What doesn't work about it? It simply turns OFF the "erase" option, that's it. Quote Link to comment Share on other sites More sharing options...
anothercadguy Posted June 26, 2008 Author Share Posted June 26, 2008 My apologies, I run the test when I hadn't activated the erase options. it does work. thanks Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 27, 2008 Share Posted June 27, 2008 oops, i guess i added too many while try this: (defun c:OFF (/ offset_dist obj_2_offset offset_side) (setvar 'cmdecho 0) (while (= offset_dist nil) (setq offset_dist (getdist "\nOffset distance: ")) );while (while (= obj_2_offset nil) (setq obj_2_offset (entsel (strcat "\nPick object to offset <" (rtos offset_dist) ">: "))) );while (while (= offset_side nil) (setq offset_side (getpoint "\nSide to offset on: ")) );while (command "offset" offset_dist obj_2_offset offset_side "") (command "erase" obj_2_offset "") (setq obj_2_offset nil) (setq offset_side nil) (princ)) Quote Link to comment Share on other sites More sharing options...
anothercadguy Posted June 27, 2008 Author Share Posted June 27, 2008 thanks alanjt, works like a charm. Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 27, 2008 Share Posted June 27, 2008 not a problem. if i get a chance this weekend, i'll actually sit down and scratch something a lot better out. i did that real quick last night w/o testing. Quote Link to comment Share on other sites More sharing options...
3dwannab Posted March 14, 2018 Share Posted March 14, 2018 oops, i guess i added too many while try this: (defun c:OFF (/ offset_dist obj_2_offset offset_side) (setvar 'cmdecho 0) (while (= offset_dist nil) (setq offset_dist (getdist "\nOffset distance: ")) );while (while (= obj_2_offset nil) (setq obj_2_offset (entsel (strcat "\nPick object to offset <" (rtos offset_dist) ">: "))) );while (while (= offset_side nil) (setq offset_side (getpoint "\nSide to offset on: ")) );while (command "offset" offset_dist obj_2_offset offset_side "") (command "erase" obj_2_offset "") (setq obj_2_offset nil) (setq offset_side nil) (princ)) Hi Alan, I tried this with decimal places offset but reverts back to the previous offset used. I tried offsetting 72.5 and it didn't work. Thanks. Quote Link to comment Share on other sites More sharing options...
tombu Posted March 14, 2018 Share Posted March 14, 2018 Hi Alan, I tried this with decimal places offset but reverts back to the previous offset used. I tried offsetting 72.5 and it didn't work. Thanks. Architectural units maybe. Try entering the line (setq offset_dist (getdist "\nOffset distance: ")) to see if it returns 72.5 Now enter the line (setq obj_2_offset (entsel (strcat "\nPick object to offset <" (rtos offset_dist) ">: "))) does it prompt "Pick object to offset : " ? Quote Link to comment Share on other sites More sharing options...
ronjonp Posted March 14, 2018 Share Posted March 14, 2018 (edited) The offset_dist variable is localized so it won't remember your last entry: (/ offset_dist obj_2_offset offset_side) Here's a simple example that saves a default offset distance: (defun c:off (/ e off p) ;; Get saved offset from registry or default to 1 (setq off (atof (cond ((getenv "MyOffsetProgram")) ("1") ) ) ) (if (and ;; Prompt for distance, if nil use default (setq off (cond ((getdist (strcat "\nOffset distance <" (vl-princ-to-string off) ">: "))) (off) ) ) ;; Pick something to offset .. needs more error checking ( ie a block will bonk it ) (setq e (entsel (strcat "\nPick object to offset: "))) ;; Pick a side to offset or use point in entsel (setq p (cond ((getpoint "\nSide to offset on: ")) ((cadr e)) ) ) ) (progn ;; Offset object (command "_.offset" off (car e) p "") ;; Delete original (entdel won't **** the bed if the object is locked) (entdel (car e)) ;; Write our default offset to registry (setenv "MyOffsetProgram" (vl-princ-to-string off)) ) ) ;; SSHHHHH!! (princ) ) (vl-load-com) Edited March 14, 2018 by ronjonp Quote Link to comment Share on other sites More sharing options...
3dwannab Posted March 14, 2018 Share Posted March 14, 2018 I found the problem to my intial problem. I had done: (defun c:ODEL nil (c:OFFSET_DELETE)) (defun c:OFFSET_DELETE ( / ) to create two command prompts forgetting about the variables. Architectural units maybe. Try entering the line(setq offset_dist (getdist "\nOffset distance: ")) to see if it returns 72.5 Now enter the line (setq obj_2_offset (entsel (strcat "\nPick object to offset <" (rtos offset_dist) ">: "))) does it prompt "Pick object to offset : " ? Yes it retruns as expected. The offset_dist variable is localized so it won't remember your last entry: (/ offset_dist obj_2_offset offset_side) This brings up the question. By deleting that variable but the script won't run with the new value which is the issue I had. Is there any way for it to remember the entered offset next run? I tried delcaring that as a global like: (defun c:OFFSET_DELETE ( offset_dist / offset_dist obj_2_offset offset_side ) But get ; error: too few arguments. Thanks, guys. Quote Link to comment Share on other sites More sharing options...
3dwannab Posted March 14, 2018 Share Posted March 14, 2018 Here's a simple example that saves a default offset distance: That's cool, thanks. I can sort out the filtering of the pick objects to filter blocks etc. I tried to get it to work so that I could pick more entities by. (progn ;; Offset object (command "_.offset" off ) (while (/= 0 (getvar 'cmdactive)) (command (car e) p pause) (entdel (car e)) ;; Pick something to offset .. needs more error checking ( ie a block will bonk it ) (setq e (entsel (strcat "\nPick object to offset: "))) ;; Pick a side to offset or use point in entsel (setq p (cond ((getpoint "\nSide to offset on: ")) ((cadr e)) ) ) (setenv "MyOffsetProgram" (vl-princ-to-string off)) ) ) But was unsuccessful. Quote Link to comment Share on other sites More sharing options...
3dwannab Posted March 16, 2018 Share Posted March 16, 2018 Got it working in a loop but just need to remove the user getting asked the offset distance each time. Here's the code until I work that out (defun c:ODEL nil (c:OFFSET_DELETE)) (defun c:OFFSET_DELETE (/ e off p) ;; Get saved offset from registry or default to 1 (setq off (atof (cond ((getenv "MyOffsetProgram")) ("1") ) ) ) (while (if (and ;; Prompt for distance, if nil use default (setq off (cond ((getdist (strcat "\nOffset distance <" (vl-princ-to-string off) ">: "))) (off) ) ) ;; Pick something to offset .. needs more error checking ( ie a block will bonk it ) (setq e (entsel (strcat "\nPick object to offset: "))) ;; Pick a side to offset or use point in entsel (setq p (cond ((getpoint "\nSide to offset on: ")) ((cadr e)) ) ) ) (progn ;; Offset object (while (command "_.offset" off (car e) p "")) ;; Delete original (entdel won't **** the bed if the object is locked) (entdel (car e)) ;; Write our default offset to registry (setenv "MyOffsetProgram" (vl-princ-to-string off)) ) ) ) ;; SSHHHHH!! (princ) ) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 17, 2018 Share Posted March 17, 2018 (edited) Wrap the Entsel in a While is not "INSERT" else do again assoc 0 is object type, or if you do a dump and look at method supported Offset is one of the methods supported. Bit like "has-attributes" checks if block has attributes. Using method means dont need to add lots of objects checking. Will try to find something. Command: DUMPIT Select object: ; IAcadLine: AutoCAD Line Interface ; Methods supported: ; .......... ; Offset (1) (setq ans "N") (while (/= ans "Y") (setq obj (vlax-ename->vla-object (car (entsel "\nPick object")))) (if (= (vlax-method-applicable-p obj "Offset") T)(setq ans "Y")(alert "Not a object that can be offset\nplease pick again")) ) Almost forgot about this, some code I have use it all the time, at any time you like it skips the need to type offset just type Oxxx and it will auto ask to offset an object a distance as define by the numbers following the O, the only quirk is for decimals need - instead of a . period, eg O123 is offset 123 it also does circles and fillet. Its part of a bigger code set so will cut out and test before posting. Edited March 17, 2018 by BIGAL Quote Link to comment Share on other sites More sharing options...
3dwannab Posted March 24, 2018 Share Posted March 24, 2018 Almost forgot about this, some code I have use it all the time, at any time you like it skips the need to type offset just type Oxxx and it will auto ask to offset an object a distance as define by the numbers following the O, the only quirk is for decimals need - instead of a . period, eg O123 is offset 123 it also does circles and fillet. Its part of a bigger code set so will cut out and test before posting. That's cool. I've modified that so it doesn't fail if nothing is selected. (defun c:TEST1 ( / obj ) (while (not (and (setq obj (car (entsel "\nSelect Offset-able object:")) ) (= (vlax-method-applicable-p (vlax-ename->vla-object obj) "Offset") T) (princ (vlax-method-applicable-p (vlax-ename->vla-object obj) "Offset")) ) ) (prompt "\nNothing offset-able selected") ) (princ) ) (vl-load-com) (princ) Quote Link to comment Share on other sites More sharing options...
3dwannab Posted March 24, 2018 Share Posted March 24, 2018 I've only got a chance to look at this today. Thanks guys for your help. Here's the working code. Done it quicker than I expected. ; ################################################################ ; ABOUT ; Offsets by specified distance. ; Distance remembered through different ACAD sessions. ; Original and majority of code done by user ronjonp here: http://www.cadtutor.net/forum/showthread.php?24646-Offset-and-delete-source&p=699122&viewfull=1#post699122 ; MY EDITS, BY 3DWANNAB ON 24.03.18 ; I've added a loop to pick more objects for offset after the first one is completed. ; and error checking to only select offset-able objects. ; It also doesn't fail if nothings selected. ; USAGE ; 'ODEL' or 'OFFSET_DELETE'. ; ################################################################ (defun c:ODEL nil (c:OFFSET_DELETE)) (defun c:OFFSET_DELETE (/ e off p) ;; Get saved offset from registry or default to 1 (setq off (atof (cond ((getenv "MyOffsetProgram")) ("1") ) ) ) (while (if (and ;; Prompt for distance, if nil use default (setq off (cond ((getdist (strcat "\nOffset distance <" (vl-princ-to-string off) ">: "))) (off) ) ) ;; Pick something to offset .. needs more error checking ( ie a block will bonk it ) ; (setq e (entsel (strcat "\nPick object to offset: "))) (progn (while (not (and (setq e (entsel "\nSelect Offset-able object: ") ) (= (vlax-method-applicable-p (vlax-ename->vla-object (car e)) "Offset") T) ; (princ (vlax-method-applicable-p (vlax-ename->vla-object (car e)) "Offset")) (setq e e) ) ) (prompt "\nNothing offset-able selected!") ) ;; Pick a side to offset or use point in entsel (setq p (cond ((getpoint "\nSide to offset on: ")) ((cadr e)) ) ) ) ) (progn ;; Offset object (while (command "_.offset" off (car e) p "")) ;; Delete original (entdel won't **** the bed if the object is locked) (entdel (car e)) ;; Write our default offset to registry (setenv "MyOffsetProgram" (vl-princ-to-string off)) ) ) ) ;; SSHHHHH!! (princ) ) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
BrianTFC Posted March 26, 2018 Share Posted March 26, 2018 3dwannab, I guess I don't understand the purpose for this lisp routine correct me if I'm wrong but the offset command that's in AutoCAD already remembers the offset distance until you change it and it also gives you the opportunity to erase the object selected. Am I missing something? Thanks, Brian Quote Link to comment Share on other sites More sharing options...
3dwannab Posted March 26, 2018 Share Posted March 26, 2018 It deletes the original object. I know there's an option to delete in offset but that's two extra steps. OFFSET>Erase>Yes>Amount as opposed to ODEL>Amount Plus it was a challenge for me to practice my LISP writing. Quote Link to comment Share on other sites More sharing options...
