Cadastrophic Posted February 22, 2005 Share Posted February 22, 2005 I have been working with a raster image (which I place on its own layer), but every time I resize the view etc, any lines in front of the image jump behind it. I can reset the draw order and send the image to the back, but it's only temporary. Is there a way to lock the image at the back? Quote Link to comment Share on other sites More sharing options...
erona Posted February 22, 2005 Share Posted February 22, 2005 Once you send the image to the back, it stays there. You only need to REDRAW ® your drawing area, if not, REGEN it. Quote Link to comment Share on other sites More sharing options...
Guest growsontrees Posted February 23, 2005 Share Posted February 23, 2005 I've found with raster images, you also have to use draworder to put all the other drawing entities in front for the raster image to stay in back permanently. Quote Link to comment Share on other sites More sharing options...
Wozza Posted February 23, 2005 Share Posted February 23, 2005 Would changing the z factor of the raster to a negative number help? Quote Link to comment Share on other sites More sharing options...
lode Posted May 27, 2009 Share Posted May 27, 2009 This still seems a hot subject, non of the above (even changing the height) proposed solutions work, except for changing the draw order of all the other objects in front of the raster image, but that's not an option for me. Am I the only one? Quote Link to comment Share on other sites More sharing options...
MRAKA Posted June 3, 2009 Share Posted June 3, 2009 I know how to solve this problem. Type "cdorder" in the command line and select the raster to want to send to back. It should stay there now. Quote Link to comment Share on other sites More sharing options...
Tallguy Posted June 18, 2009 Share Posted June 18, 2009 My rasters and any text with background keep changing order, cdorder doesn't seem to help, any more ideas? Frustrating! Quote Link to comment Share on other sites More sharing options...
MRAKA Posted June 18, 2009 Share Posted June 18, 2009 After the Cdorder command send your raster to back and then regen. Its really annoying I know!!!! Quote Link to comment Share on other sites More sharing options...
Tallguy Posted May 4, 2010 Share Posted May 4, 2010 Tried all these, still no luck, annoying rasters keep jumping to front. Any other ideas? Quote Link to comment Share on other sites More sharing options...
LarsT Posted May 14, 2010 Share Posted May 14, 2010 Select the image, right click on it, and then select "Draw Order". This will allow you to send the image to the back. I use a lot of raster images, temporarily, to aid me in creating perspective drawings for patent applications. I wish there were a way to send an entire layer to the back, but I haven't found it yet. Quote Link to comment Share on other sites More sharing options...
Tallguy Posted May 17, 2010 Share Posted May 17, 2010 Select the image, right click on it Right clicking repeats previous command in my set up. Can you clarify what you did? Using Map3D 2008: To send an entire layer to back, I select every entity on that layer, then use the DRAWORDER command. The easiest way of doing this is QSELECT Then set the dialog box as follows: Apply to: Entire drawing Object type: Multiple Properties: Layer Operator: =Equals Value: (select the layer you want to send to back or otherwise change) How to apply: Include in new selection set Append to current selection set: UNchecked. OK. Then use the Draw Order toolbar or DRAWORDER command to put all the entities where you want them. No doubt someone more qualified will be along shortly to demonstrate a much easier way! Quote Link to comment Share on other sites More sharing options...
LarsT Posted May 17, 2010 Share Posted May 17, 2010 I'm using AutoCAD 2005 - I don't have Map3D. Here's what my manual says about draw order: Control How Overlapping Objects Are Displayed Generally, overlapping objects ... are displayed in the order they are created: newly created objects in front of existing objects. You can use DRAWORDER to change the draw order (which is the display and plotting order) of any objects. TEXTTOFRONT changes the draw order of all text and dimensions in the drawing. Note Overlapping objects cannot be controlled between model space and paper space. They can be controlled only within the same space. To change the draw order of overlapping objects 1 On the Draw Order toolbar, click one of the draw order options. 2 Select the object(s) whose draw order you want to modify and press ENTER. 3 Select the reference objects(s) and press ENTER. (This step is necessary only for the Bring Above Objects and Send Under Objects options.) Tools Menu Draw Order Command line DRAWORDER Shortcut menu Select an object, right-click, and then click Draw Order I used the shortcut menu. Quote Link to comment Share on other sites More sharing options...
WtaDude0822 Posted May 17, 2010 Share Posted May 17, 2010 Make your image transparent...type transparency at the command prompt, select your image and set it to on. Quote Link to comment Share on other sites More sharing options...
lode Posted May 18, 2010 Share Posted May 18, 2010 Hi LarsT, I really liked your post, at first, I thought it was a bit ironic, because, the theory is perfect, but still, in reality, it simply doesn't work. Each and every time, the raster images keep popping up to the front. When performed the draworder command, sometimes, freezing and unfreezing the raster image layer works well, as well as regen, but you always have to perform an action to obtain the correct draw order again (for some time ...) aaaaaaaaaaaaargh, We were thinking about buying acad maps because we think it should handle raster images in a better way, but it seems like Tallguy has the same problems! man man man, keep on searching everybody, because it seems like we are the only people on the internet having this problems (and all my colleagues aswell ) Quote Link to comment Share on other sites More sharing options...
WtaDude0822 Posted May 18, 2010 Share Posted May 18, 2010 What's your DRAWORDERCTL variable set to? Quote Link to comment Share on other sites More sharing options...
lode Posted May 19, 2010 Share Posted May 19, 2010 three, as it should be?! thank you for thinking about this like this. I assume it is something like this that causes the problem... Quote Link to comment Share on other sites More sharing options...
DanSandy Posted August 30, 2011 Share Posted August 30, 2011 Finally found a solution to this!!!! In AutoCAD on the command line type: 3DCONFIG Click on "Check for updates"... allow it to update all those drivers... Then make sure you are using the most current video driver for your video card. Stop pulling out your hair and get working!!! Hope that helps! `Dan Quote Link to comment Share on other sites More sharing options...
tim-steenhuis Posted May 17, 2013 Share Posted May 17, 2013 I think i got it. Set "draworderctl" to 0. This way, regardless of their draw order, new objects are displayed on top until a drawing is regenerated (REGEN) or reopened. (I also set "imageframe" and "frameselection" to 0, and place image in a layer that is lower on the list than the ones I draw in) Hope this helps! Quote Link to comment Share on other sites More sharing options...
