Results 1 to 4 of 4
    Senior Member BOB'27T's Avatar
    BOB'27T's Computer Details
    Dell Precision 690
    Dual 21" Dell
    Civil 3D 2009
    Sep 2007
    Tavares,Florida
    416
    Default Adding global width to a circle
    Here's a little trick I learned a while back. I needed to add thickness to a circle & found a slick way to do it. Here goes: Start by making a polygon with 4 sides. Check inscribed in circle when prompted. Next specify your radius. That will create a square. Then select polyline edit, then select fit, then width. Tah Dah! You have a circle with a global width!
    "Those Who Pay Attention Will Be Rewarded"
    Junior Member
    AutoCAD 2010
    Feb 2010
    14
    great tip - saved me today
    Forum Newbie
    AutoCAD 2011
    Dec 2012
    1
    The DONUT command can probably also give you a similar result. Specify the inner and outer dimensions, and voila!
    Forum Newbie
    Omer Saif's Computer Details
    Windows 7
    HP
    8 GB
    Architectural
    Omer Saif's Discipline Details
    Engineering Techician
    Architectural
    Architecture, Urban Planning, Landscape
    AutoCAD 2013
    Jun 2013
    Bahrain
    2
    Thanks ... ..
  1. Draw Polyline with global width?
    By comcu in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Jul 2008, 10:32 am
  2. Create a circle with a width
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 30th Nov 2007, 11:10 pm
  3. Replies: 0
    Last Post: 24th Jan 2007, 11:10 pm
  4. Polylines with Global Width to Boundaries
    By daiharv in forum AutoCAD Drawing Management & Output
    Last Post: 20th Dec 2006, 10:00 am
  5. global width lines
    By drahcir in forum AutoCAD Drawing Management & Output
    Last Post: 19th Oct 2006, 12:48 pm
