Results 1 to 3 of 3
    Senior Member
    AutoCAD 2009
    May 2008
    Philadelphia, Pa.
    407
    Default Change Layer Prefixs and Layer Names
    Hi
    I helped a CADTutor member the other day via a pvt message and I thought it might be good to share it with everyone else.
    The first Sub will change the layer prefix (From - To)
    The second Sub will iterate through the layer collection and ask users if they want to change layer names.
    Both filter out Layer 0 and and the second one also filters out 0 and layers with the prefix that you give it. It probably could also be tweaked to work with wild cards, I haven't tried it.
    ML
    Code:
    Sub ChangeLayerNamePrefix()
     Dim lay As AcadLayer
     Dim cwLayNames As String
     Dim ncwLayNames As String
    'Update Layer name prefixs
     For Each lay In ThisDrawing.Layers
      If Not lay.Name = "0" Then 'Filter out Layer 0
       cwLayNames = lay.Name
       'Starting from char 1 of the layer name, if string CW- exists then
        If InStr(1, cwLayNames, "CW-", vbTextCompare) Then
        'In string variable cwLayerName, replace CW- w\ ATT-
         ncwLayNames = Replace(cwLayNames, "CW-", "ATT-", , , vbTextCompare)
         lay.Name = ncwLayNames
         Debug.Print "Layer " & cwLayNames & " has been changed to " & ncwLayNames
        End If
       End If
     Next lay
     Set lay = Nothing
    'Call ChangeLayerName
    End Sub
    Code:
    Sub ChangeLayerName()
    Dim layName As String
     'Filter out all layers with the prefix ATT-
      If Not InStr(1, lay.Name, "ATT-", vbTextCompare) > 0 Then
    Repeatlay:
      'Return to user, layers to renamed
       If MsgBox("The layer " & lay.Name & " is a non standard layer," & vbCrLf & _
       "do you want to rename this layer?", vbYesNo, "cwLayers") = vbYes Then
       'Prompt the user for new layer name
        layName = InputBox("Enter new layer name for layer " & vbCrLf & lay.Name)
         If layName = "" Then
          MsgBox "All layers must have a name, " & vbCrLf & "Please Click No " & _
          "if you do not want to rename layer: " & vbCrLf & lay.Name, vbCritical
          GoTo Repeatlay
         End If
         lay.Name = layName
         Debug.Print layName
        End If
       End If
     End If
    Next lay
    Set lay = Nothing
    End Sub
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,833
    Thank you ML0940 for sharing your code with us. I'm sure there are those of us that will find this routine quite helpful.
    Senior Member
    AutoCAD 2009
    May 2008
    Philadelphia, Pa.
    407
    Hi Remark
    Sure, no problem!
    Thank you for the appreciation
    I helped someone privately which I did not mind but after looking at the code tonight, I thought that it is only fair that others see it as well.
    I hope that others will find it useful or even suggest other ways of using it.
    Enjoy!
    Any questions, for free to ask
    ML
  1. Change layer and return to layer using button
    By Vigilante in forum AutoCAD General
    Last Post: 6th Sep 2007, 07:01 pm
  2. Layer Names
    By greenbigg in forum AutoCAD Beginners' Area
    Last Post: 26th Dec 2006, 06:35 pm
  3. Changing layer names
    By Alan Cullen in forum AutoCAD Drawing Management & Output
    Last Post: 9th Oct 2006, 12:03 am
  4. Layer names
    By RHOS1355 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Jun 2006, 11:19 pm
  5. Importing Layer Names
    By blueroly in forum AutoCAD Drawing Management & Output
    Last Post: 21st Oct 2005, 03:06 pm
