Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 34
    Full Member NiceGuy8618's Avatar
    NiceGuy8618's Computer Details
    Weak and Old
    AutoCAD LT 2006
    Jun 2008
    Dead Center California
    36
    Default Can't explode block
    I'm trying to explode this block in a drawing i'm editing but autocad will not let me do this. Sorry for the newbness of this question, but is there something i'm missing. Could it be locked? Is that possible? Thanks
    Senior Member
    Secretagdan's Computer Details
    Windows 7
    Custom
    8.00 GB
    NVIDIA Quadro 2000
    INTEL SSDSC2MH120A2
    (2) Samsung 226BW 22" Monitor(s)
    Manufacture
    Secretagdan's Discipline Details
    Detailer--Exhibits
    Manufacture
    I draw stuff people build it.
    AutoCAD 2014
    Oct 2007
    Hillsboro, OR
    231
    Is the block an X-ref? If it is you will need to bind it before you can explode it.
    Weak and Old
    AutoCAD LT 2006
    Jun 2008
    36
    It's not an xref. I should also mention that I have Autocad lt
    Senior Member JerryG's Avatar
    JerryG's Computer Details
    Never Good Enough
    My head
    Notebook
    Its big
    Civil
    JerryG's Discipline Details
    Stream Restoration
    Civil
    Civil 3D 2015
    Jan 2008
    Washington State
    418
    Is the layer your inserting it on Locked?
    Never trust a computer you can't throw out a window!
  5. #5
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Life's constantly changing - keep up or get left behind
  6. #6
    Weak and Old
    AutoCAD LT 2006
    Jun 2008
    36
    Ok, so after a particular block is checked to not allow exploding, how can I uncheck that option?
  7. #7
    Weak and Old
    AutoCAD LT 2006
    Jun 2008
    36
    I tried refedit but aparantly that doesn't work. Is this because I have lt version?
  8. #8
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Start the block command, select the block, check "Allow exploding"
  9. #9
    Weak and Old
    AutoCAD LT 2006
    Jun 2008
    36
    Thank You
  10. #10
    Weak and Old
    AutoCAD LT 2006
    Jun 2008
    36
    Oooooooooook. So I didn't have time to try that out yesterday, but I assumed that it would work. I'm having trouble editing the block definition after the blocks are already drawn. So I go into the Block Definition box and I choose the particular block that I'm working with and I go to the "Allow exploding" check box and I check it. After hitting ok I get the message "conv is already defined. 139 block references already exist in the drawing. Update the defintion and all of its block references?" I hit yes and it it deletes all of the 139 blocks. So can I change this property after the blocks have already been drawn?
  1. xref block explode
    By russell84 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Apr 2008, 03:39 pm
  2. Insert a .tiff as an explode-able block?
    By Moe` in forum AutoCAD General
    Last Post: 29th Aug 2007, 02:31 pm
  3. Explode/extract out only part of a block?
    By Vigilante in forum AutoCAD Drawing Management & Output
    Last Post: 6th Apr 2007, 08:45 pm
  4. How to explode title block?
    By salmoon in forum AutoCAD Drawing Management & Output
    Last Post: 17th Dec 2006, 11:45 pm
  5. explode block
    By wastewater in forum AutoCAD Drawing Management & Output
    Last Post: 27th Oct 2006, 05:03 pm
