Search the forum for rotating and scaling blocks particuarly the lisp vba section I am sure there will be an answer there
is there anyway to rotate blocks associated with desc keys globally and not having to manually do it?
is there a way to make a block come in at double whatever the drawing scale is?
I had to draw the layout of a brewery. Namely all motors that drive all the conveyors. I had a hundred or more to do (SEW eurodrive gearmotor) with 4 different orientations.
I made 4 buttons on my menu calling the same block. below is only one of the buttons inserting the block and rotating it 180
[_Button("ext", "macRIGHT.bmp", "macRIGHT.bmp")]^C^C-NSERT;sew-p;R;180;\;;
You can do the same with cui, (I'm too stubborn and still do it the old way)
I'm now a senior member.
Someone may think that I know what I'm doing. If so, I sure fooled them!
The example is insert rotate 180. You can also/instead put in scale 2
