Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
  1. #21
    Forum Newbie
    Architecture 2011
    Apr 2012
    9
    Patrick, I'm having the same trouble as you. I've tried every conceivable combination of parameters and grips - including chaining a second distance parameter vertical at the door to chain to the horizontal opening width parameter - but either the door leaf skews or the linear parameter grip rotates along with the leaf. I cannot replicate the behavior of this excellent block! Has anyone else figured this out?
  2. #22
    Senior Member nod684's Avatar
    nod684's Computer Details
    Windows 7 Home
    Architectural
    AutoCAD 2014
    Jul 2012
    Philippines
    345
    Using Angular Dimension for the arc!...very nice!
    thanks for sharing!
    "Memories fade but the scars still linger...."
  3. #23
    Super Member
    Architecture 2010
    Jan 2006
    canada, eh!
    607
    Quote Originally Posted by Patrick Jones View Post
    How did you "include" the stretch parameter with the rotation parameter?
    Patrick
    hummm....i did this block with version 2008...back then when you added an action you can place it where ever you wanted so i placed it at the end of the door...then when i added the rotation parameter i was able to select that stretch action...can't seem to recreate this effect in 2010 because autocad now automatically groups/places the action next to the parameter and those actions are no longer selectable to be able to be included with another action?..
    mark this up as progress--lol...
  4. #24
    Super Member
    Architecture 2010
    Jan 2006
    canada, eh!
    607
    hey, just did some poking around and found a variable that will display the action in "legacy" mode...
    bactionbarmode set to 0 will bring back the old system of displaying the action as "lightning" icons and will allow you to add that "lightning" as part of a selection set!..
    i have now been able to replicate the block behaviour in 2010!..
  5. #25
    Forum Newbie
    AutoCAD 2014
    Apr 2015
    1
    Thank you so much.....Ive been working on this for ages!....and couldn't sort it
    Cheers
  6. #26
    Full Member
    Jman's Computer Details
    windows 7
    hp Z420 workstation
    8.00 GB
    (2) hp zr2440w
    Manufacture
    Jman's Discipline Details
    I am a Draftsman for a Design-build company
    Manufacture
    I create working drawings for a Modular Building Company, Mostly Schools
    AutoCAD 2018
    May 2015
    Northern California
    32
    Default Question
    I have created a dynamic door block in Acad 2018 using your swing arc which works very well. I'm wondering if you could take a look at it as the swing and
    the arc rotates but when i rotate the swing and try and change the door size,
    the door rotates past the swing degrees i have set it to. This block is very complex
    (probably only to me) as iv'e had to add accessible signage and clear space as
    they are for school projects. I have no problems if i adjust the size at 90 degrees
    and then rotate the door but i was hoping i could resize the door with the swing
    at any set degree. Any help would be appreciated
    EXT DOOR - ADA - RESTROOM AND REGULAR.dwg
  7. #27
    Junior Member markwheeler303's Avatar
    Construction
    AutoCAD 2017
    Oct 2017
    20
    Unfortunately not.
    The stretch you have set to control the doors actual length will only stretch vertically. As soon as you change the angle of the door and then attempt to stretch it just pulls it out of shape.
    You will always have to follow an order of operations for this block to work.
    You could remake this block using geometric and dimensional constraints though. It would be overly complicated how ever.
  8. #28
    Full Member
    windows 7
    hp Z420 workstation
    8.00 GB
    (2) hp zr2440w
    Manufacture
    Manufacture
    AutoCAD 2018
    May 2015
    Northern California
    32
    Thanks Mark,
    I think i'll use it the way it is. I haven't worked with geometric and dimensional constraints yet.
  1. Casement Window Swing Direction
    By Pineapple in forum CAD Management
    Last Post: 4th May 2012, 05:01 pm
  2. Door Swing
    By slipperyer in forum AutoCAD Beginners' Area
    Last Post: 27th Dec 2011, 02:28 pm
  3. AutoCAD Tutorial: Create a dynamic block of a door
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 24th Dec 2008, 11:03 pm
  4. Lsp variable within a Dynamic block?
    By whteglve in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Feb 2008, 07:27 pm
  5. Garage door
    By jared98366 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Jan 2007, 03:27 am
