I have bought a couple of Authorized Training Courseware from Autodesk. Go here: http://www.adskconsulting.com/course...seware_cat.php
Pick AutoCAD MEP from the Dropdown menu and select which trade you will be needing. Very informative books.![]()
hey every one .
any body have book ,vedio , site learn autodesk mep??
Tannar Frampton | Facilities Engineering | Revit 2013
Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
Can you get these cheaper any where, or in PDF?
Nick
Not that I know of. Trust me they're worth the money if you're starting out.
Other than that, just monkey around with the program via tutorials online and what not. It takes time to learn MEP that's for sure.![]()
We dont use it at our company (of 3 weeks) im getting more involved with the engineering side of things now instead of doing just CAD, (got no engineering quals) but will be working close with Mech designers, and want them to get onto MEP in the future - so want to get good/ok at it
what are in the books? are they like step by step? and tell you how to draw things etc...
Yeah one of them gives you a step by step run through for every trade involved in the program, plus all the extras like Layer Key Styles, Property Sets, Dynamic Scheduling, etc. It's what gave me the boost to get going. Once I did it, MEP became logical to me and I started figuring things out on my own.![]()
Is MEP still good to use in 2D? I want to use MEP the next time I have to do a Ducting drawings. But i want to get into doing 3d boiler/plant rooms, as im working on alot of them at the minute and i think the engineer i work for would like to see what I could do instead of 2d schematics
There's a learning curve, but yeah it produces EXCELLENT 2D plans, especially when you start understanding the architecture of the program. That's why at my company, AutoCAD MEP has priority over using Revit because we are not only an engineering firm, we also are a construction company so our prints need to be "field friendly" for our guys to install it. AutoCAD MEP does very well in this department, and once you get fast at it you can REALLY pump out some plans, especially when coordinating with elevation issues.![]()
Think im going to get the HVAC one and have a play, I tried to have a go at a tutorial on Youtube, but i wasnt doing something right? and couldnt see the video proper (well what it was showing what to do)
Are you in the building services field?
Yeah, we do HVAC, Piping, and some plumbing. We are an engineering firm as well as a construction company, so I do it all. Plus I started in the field right outta high school so I have 3.5 years of field experience, which gives me a bit of an edge when designing.![]()
