Results 1 to 3 of 3
Thread: ltype?
    Full Member fbby's Avatar
    AutoCAD 2008
    Apr 2008
    53
    Default ltype?
    I have received some drawings, in the folder file there is a LTYPE support folder, when I open it there are different file (.shx, .shp and .lin), can anyone tell me what is this and how it works for the received drawings?
    thanks
    ________________________
    sorry for my english
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    You should just need the .shx file to show custom linetypes in the received file. You could place this file in the same folder as the drawing when you open it, the shx file should be found. if not you will get a message about missing shx file.
    AutoCAD 2008
    Apr 2008
    53
    I will place the .shx, .shp and .lin files together in the same folder with the drawings or .shx file only?
    thanks
    ___________________
  1. Ltype Gen Fails Me
    By BIGMIKE09281946 in forum Student Project Questions
    Last Post: 3rd Dec 2008, 05:06 pm
  2. Move objects to new layers using color/ltype/line weight
    By chulse in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Sep 2007, 01:49 pm
