Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2009
    Jul 2008
    4
    Default Patterning Cells Periodically Along 3D Object
    Hi All,
    I am not sure what the best way to do the following is:
    I have a pattern that needs to be repeated periodically along a 3D object. The simplest case is a 3D cylinder and I eventually want to do it on something more complicated, say a distorted sphere. Since the pattern I have is just a 2D object, I need to conform/project/map it onto the 3D object.
    1.) What is the best way to do this in AutoCAD?
    2.) Shoould I do this in Inventor? If so, does anyone know how?
    Thank you,
    Conformal
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    228
    Do you mean something like the attached??
    Regards
    Jochen
    Forum Newbie
    AutoCAD 2009
    Jul 2008
    4
    Hi Jochen,
    Yes, I want to do something similar. Can you please explain how you did this? It will help me get started.
    Thank you,
    Conformal
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    228
    I take a flat pattern consisting of (LW-)Polylines and transform the coordinates from each vertex from Cartesian to cylindric (or spherical) coordinates. After getting this list of the transformed vertex coordinates I connect them by a 3DPoly. Notice, that there are no real arcs or splines on the surface - this are only linear segmented 3DPolys.
    In case of more information contact me via www.black-cad.de
    Jochen
  5. #5
    Forum Newbie
    AutoCAD 2009
    Jul 2008
    4
    Hi Jochen,
    So I guess you wrote a custom script to do this?
    Thank you,
    Conformal
  6. #6
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    228
    Yes Sir
    Regards
    Jochen
  1. Unlocking Cells!!!
    By ankers in forum AutoCAD Drawing Management & Output
    Last Post: 9th Apr 2008, 12:30 pm
  2. Camphor cells & entomological cabinets
    By Bespoke in forum Catch All
    Last Post: 30th Sep 2007, 08:39 pm
  3. How autolisp recognizes table cells?
    By oji_d in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Aug 2007, 06:02 am
  4. Saving dwg files with imported excel cells as pdfs
    By Wolvie in forum AutoCAD General
    Last Post: 10th May 2006, 11:17 pm
  5. ... Insert attribute information into specific Xcell Cells?
    By Pablo Ferral in forum AutoCAD General
    Last Post: 13th Apr 2005, 07:32 pm
