Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 55 of 55
  1. #51
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,169
    Quote Originally Posted by kjoseph86 View Post
    So I just unlocked the viewport
    Well, that cleared it up, but I still had to figure out how to do it.
    For anyone else that is wondering, this is how to unlock a viewport while it is active:
    Drafting is a breeze.
  2. #52
    Forum Newbie
    Map 3D 2012
    Dec 2015
    2
    Default Can't view vport
    I had the problem of not being able click on the vports. I had to click on the vport to activate the grips, then right click to pull up the menu. Click on Display Viewport Objects. My settings where checked "Yes", but I click on "No" and exited and the re-set to "Yes". Vports are now visible. I hope this helps.
  3. #53
    Forum Newbie
    Map 3D 2012
    Dec 2015
    2
    In additional to my last post, I just discovered that I had multiple copies of Vports stacked on top each other. Once I deleted the the extra copies the problem went away.
  4. #54
    Senior Member MillerMG's Avatar
    MillerMG's Computer Details
    Windows 7
    OPTIPLEX 3020
    Intel(R) Core(TM) i5-4570 CPU @ 3.30GHz
    8.0 GB
    The two in front of me. Dude, I got Dell's
    Civil
    MillerMG's Discipline Details
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    436
    Good to know!
  5. #55
    Forum Newbie
    AutoCAD 2014
    Feb 2016
    1
    Not sure what causes the problem, but a solution that worked for me: Change your current layer to "0". type "audit". select "Y".
  1. unable to select the whole drawing
    By sparkyuk in forum AutoCAD Beginners' Area
    Last Post: 10th May 2007, 05:43 pm
  2. Unable to select Text
    By Jon J in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2007, 11:42 pm
  3. Unable to delete viewport
    By bugleboy62 in forum AutoCAD Drawing Management & Output
    Last Post: 21st Feb 2007, 08:37 pm
  4. Unable to delete viewport
    By bugleboy62 in forum AutoCAD Beginners' Area
  5. Unable to adjust scale in viewport
    By waltpeat in forum AutoCAD Drawing Management & Output
    Last Post: 17th Aug 2006, 02:37 pm
