Results 1 to 2 of 2
    Full Member
    AutoCAD LT 2009
    Jul 2008
    28
    Default Trying to draw a coil in 2D
    Is there any easy way to draw a simple coil shape? Just a curved line like one would find in a spring. I have tried using the spline tool, but the line ends up wonky, and if I used the arc tool with straight lines, it looks too regimented. Am I banging my head against a brick wall here, or is there an easier way?
    Senior Member cpriedel's Avatar
    AutoCAD 2014
    Sep 2007
    From Germany to Seattle
    169
    try this looks like its what ur looking for
    http://www.xaraxone.com/webxealot/workbook19/page_6.htm
    just did a quick search in google
  1. how to create a 3d coil spring
    By alanie88 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Feb 2009, 01:55 pm
  2. Coil Cutout
    By vinod in forum Autodesk Inventor
    Last Post: 18th Aug 2007, 11:01 pm
  3. Coil
    By Andy44 in forum Autodesk Inventor
    Last Post: 18th Apr 2007, 08:02 pm
  4. can u make a coil spring?
    By rohit mahajan in forum AutoCAD Beginners' Area
    Last Post: 14th Dec 2005, 04:01 pm
  5. Swept coil?
    By Jmar in forum Autodesk Inventor
    Last Post: 10th Aug 2005, 11:01 am
