Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    When you go into PS, go into the viewport, do a zoom, extents, exit the viewport, select the viewport border, using properties, find the annotation scale, use the drop down to set it at 1/4"=1'-0".
    There are other ways to do this, just trying to find the easiest to describe.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  2. #12
    Super Member
    not specified
    Feb 2006
    527
    I had to set the annotation scale 1/4"=1' before in the viewport before
    I could see the annotation text.
    I see a annotation text setting in model space and annotation text as a view
    port property variable. In the view port there is also a scale variable.
    So what is all the scales for and how do they relate and work ?
    Please explain all the annotation & scale variables.
    Thank you,
  3. #13
    Super Member
    not specified
    Feb 2006
    527
    Default Annotation text scales
    We have an annotation scale in model. We have annotative scale property
    in PS view port. We have a scale property in paperspace view ports.
    What is all the annotative scale for? How do they relate?
    thank you,
  4. #14
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Did you get a chance to read the reference materials suggested in post #5? It's all explained there.
  5. #15
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    MS annotation scale (annoscale) is there to display annotation objects
    at the currently set annoscale.
    PS annoscale is there to display annotation objects at the currently set
    viewport annoscale.
    Viewport scale is there to display the geometry (any non-annoscale objects)
    in MS to a plot scale.
    The purpose of all of this.
    In MS you can set annoscale objects to one or many annoscales, say 1/4" and 1/8".
    You would do this because you may have a plan view in 1/8" plot scale and want
    the text to show up the correct size in PS for plotting. You may also have
    an enlarged plan at 1/4" plot scale. Now you will want the text to still
    display and plot to the same height in PS, so you set the viewport scale to
    1/8" and the annoscale to 1/8". Only the annoscale objects set to 1/8" will
    display.
    If you set the viewport scale to 1/4", this does not set the annoscale for that
    viewport to 1/4", you must also set the annoscale for that viewport. However if
    you set the annoscale for that viewport the viewport scale will scale to that
    same value automatically.
  1. Printer cartridge usage
    By cadam in forum AutoCAD Drawing Management & Output
    Last Post: 21st Aug 2008, 06:10 am
  2. Off Subject - 100% Cpu usage
    By VIC842 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Apr 2007, 10:56 am
  3. VB USERFORM Usage
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Mar 2007, 09:18 pm
  4. Mouse/CPU usage issue
    By stefhelm in forum AutoCAD Drawing Management & Output
    Last Post: 15th May 2006, 05:05 pm
  5. Effricient Memory usage
    By superjari in forum AutoCAD Drawing Management & Output
    Last Post: 9th Feb 2003, 01:43 pm
