Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Full Member
    AutoCAD 2008
    Jun 2008
    35
    Default Insert an Excel sheet into autocad
    Hi
    I have an excel sheet which contains tables of some calculations
    i have copied it from excel to autocad. it was copied but the autocad has taken it as image
    but i want it as editable or convert it into autocad means the table has to be editable in autocad
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,132
    You should have "linked" the spreadsheet not copy it into a drawing. Follow the prompts in the Table creation Dialog box. The table can be found on the Draw toolbar, the Draw pulldown and the Dashboard.
    Once the link has been established you'll find it works in either direction. Data links can include the entire spreadsheet, a single cell or even a range of cells.
    Forum Newbie
    AutoCAD 2006
    Mar 2008
    1
    i can't understand, can u explain clearly what procedure?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,132
    Two-way links between AutoCAD and Excel were introduced in AutoCAD 2008 although I believe there were add-on programs that claimed to do this using earlier versions.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,132
    Bi-directional linking of AutoCAD and Excel:
    http://www.xanadu.cz/en/excellink.asp
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,132
    Using Excel spreadsheets inside AutoCAD. A work-around:
    http://www.dotsoft.com/xl2cad.htm
  7. #7
    Forum Newbie
    AutoCAD LT 2008
    Mar 2009
    1
    Default Xcl2cad
    A 'FREE' way to do it...
    I am sure thr r many ways to do this but here's what i can tell you:
    1)In Excel: Copy cells you want in autocad
    2)In Autocad: Paste special --> autocad entities; you should now get a "excel looking" table in autocad.
    You can get effieient by linking this table to your Excel file, this way you would only have change you Orginal Excel file and Autocad would update (almost) automatically,
    So after step 2, step 3) is select your data in autocad, by selecting ->ROW1COL1 then ->SHIFT KEY -> endROW endCOL-->RIGHT CLICK ->"LINK CELL/DATA LINK" Here you can select your range of data or select the whole excel sheet to show up in autocad. If you make any changes in Excel it will not update autocad (just yet). You have to go into Autocad Right click on any RowCol and goto DATA LINKS -> DOWNLOAD CHANGES FROM SOURCE FILE. Your autocad xcl sheet should now updat to match Excel sht.
    Quote Originally Posted by Sudhir View Post
    Hi
  8. #8
    Full Member
    AutoCAD 2009
    Sep 2011
    54
    hi,
    i found this trick to be extremely useful, i did it using the data link command. sort of created an external refrence, if the excel sheet changed i can update that in autocad in a single click. Can i bind permanently this sheet in autocad? just like we bind xref dwg files. ?
  9. #9
    Super Member Bill Tillman's Avatar
    AutoCAD 2013
    Oct 2008
    Miami, FL
    871
    I had some experience with this process recently so allow me to put in my 2 cents worth here.
    The process can be done at no charge using the tools you have in AutoCAD and MS Office. The process can be messy though and so 3rd party software which can assist in this is worth looking at.
    I found that bringing the Excel table into AutoCAD is easier if you strip the table down to just the bare essentials. If you have lots of things in the table like merged cells, extra columns, etc....it will make formatting or making it look good in AutoCAD a nightmare. This is where the 3rd party add-ons seem to offer help. I tried one of the trial versions but it was way too limited and I was not about to pay $$$ to test something out. Perhaps I can try another option from another 3rd party vendor later.
    My success came when I took the very complicated table the engineering team created and reduced it to only 3 columns it was quite easy to get it into AutoCAD and make it look like it belonged in the drawing, not a pasted in OLE object. Plus it can be updated when the Excel file is updated, etc....
    I will certainly look to expand my capabilities with the built-in tools. But my first experience with this process shows it to be slow and cumbersome, even if you know what you're doing. There were times when it took the DataLink manager about 3 minutes to respond. I thought AutoCAD had locked up but the task manager showed it was still working and responding. Still the DataLink manager windows were just sitting there for what seemed like hours. It takes patience to get it done.
    It's deja vu, all over again.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,132
    I used to use the "paste special" technique but switched to the DataLink method when it was first introduced and never went back. I've used the method now about a dozen times. Our spreadsheets do not tend to be complicated so that probably explains why the method has been so successful for us anyway.
  1. Insert Excel file to Cad
    By BEKA in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jan 2010, 05:37 pm
  2. Drawing A Line From A Excel Sheet
    By pkp.pk in forum AutoCAD Beginners' Area
    Last Post: 30th Jul 2008, 03:05 pm
  3. Exporting Attributes to an excel Spread Sheet using AutoCAD 2008 VBA
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jan 2008, 09:36 pm
  4. controlling titleblock attributes with excel sheet
    By comcu in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Aug 2007, 10:14 pm
  5. printing a dwg with excel sheet linked
    By Archi in forum Autodesk Software General
    Last Post: 2nd Nov 2005, 03:13 pm
