Results 1 to 6 of 6
    Junior Member
    AutoCAD 2007
    Jan 2007
    11
    Unhappy Dimesioning Text Height style change
    Hi. I'm wondering how to do something. I have AutoCAD 2008LT. I'm putting dimensions on detail drawings. I'm changing the size of the arrows and text since I'm printing in different viewport scales and the changes make them match. Oddly , I have recently found that instead of making the text 12" or 6" in height (as I have always done), the Dimention Style Manager says the arrow size, for example, is 1/8" ht . I would rather work in inches. Is there a way to switch it back to inches because that would be easier for me?
    Thanks,
    sm
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    It seems to me that you are still working in inches- maybe you've changed a scale somewhere?
    "To alcohol; the cause and solution to all of life's problems." - Homer Simpson
    Junior Member
    AutoCAD 2007
    Jan 2007
    11
    It's happening to every drawing now. I have many dim styles - all of them have been converted to using the fractional method of scaling text and arrows, etc. I wish I could switch it back to inches. The drawing units are architectural and in inches (same as before).
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Quote Originally Posted by samla02 View Post
    ...I wish I could switch it back to inches...
    Your initial post suggests you still are using inches- 1/8" = one eighth of an inch. It's not to do with the units unless I'm somehow mistaken??? Anyone?
  5. #5
    Junior Member
    AutoCAD 2007
    Jan 2007
    11
    Guess What! I figured it out.
    Somehow in the dimension style standard, in the modify dimension style standard, there is a tab for FILL and in that tab, the scale for dimension features was a box checked for - use overall scale of - (in this case '96'). I changed it to 1. After that I was able to change all the dimensions to inches measurements and everything is back to the way I like it (at leat in my new dim style and in this drawing).
    I'm happy. I'm still not sure how it happened. Maybe I copied something into the file that had a weird dimension style. I'm new at this.
  6. #6
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Aha! Congratulations!!!
  1. Code to change text height
    By JONTHEPOPE in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Apr 2009, 12:16 pm
  2. Change default text style
    By Robert J in forum AutoCAD Beginners' Area
    Last Post: 3rd Oct 2007, 07:54 pm
  3. change cross section text height
    By MikeP in forum AutoCAD Drawing Management & Output
    Last Post: 9th Apr 2007, 04:05 pm
  4. How do I change the plot stamp text height in MicrostionV8?
    By CHRISD5150 in forum AutoCAD General
    Last Post: 4th Jan 2006, 02:34 pm
  5. Text height
    By Siberian in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Aug 2005, 05:05 pm
