Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Template help
    Full Member dboy413's Avatar
    dboy413's Computer Details
    Windows xp
    Dell optiplex 745
    2gb
    AutoCAD LT 2010
    Jul 2008
    Fort worth, Texas
    47
    Question Template help
    does anyone know how to set my personal template file to open instead of "drawing 1"???
    Senior Member cpriedel's Avatar
    AutoCAD 2010
    Sep 2007
    From Germany to Seattle
    155
    make sure your Template File is saved as .dwt than you just have to go to tools -> options -> Tab "Files" -> scoll down to "Template setting and browse to the path where you have your template saved under "Default template for sheet creation and Page setup override".
    (not 100% thats the one maybe "Drawing Template file location" instead).
    We just have a Standard .dwg file that we open and start working on. We never start a new drawing via Autocad only via explorer and "save as" to the desired location.
    Hope that helped.
    Windows xp
    Dell optiplex 745
    2gb
    AutoCAD LT 2010
    Jul 2008
    Fort worth, Texas
    47
    Thanks i'll give it a shot
    Windows xp
    Dell optiplex 745
    2gb
    AutoCAD LT 2010
    Jul 2008
    Fort worth, Texas
    47
    Smile
    Man thank you so much!! That worked perfectly
  5. #5
    AutoCAD 2010
    Sep 2007
    155
    Sweet! Glad to help
  6. #6
    Forum Newbie
    AutoCAD 2009
    Mar 2009
    7
    Save your template as the acad.dwt in the template folder. Acad.dwt is always your startup template.
  7. #7
    Forum Newbie
    AutoCAD 2007
    Oct 2009
    6
    how do i can get your standard template here in the website so i can use it to my projects for easy insertion of templates
  8. #8
    Forum Newbie
    AutoCAD 2009
    Mar 2009
    7
    You need to create the template with the standards that you wish to use, once you have it created then save it as acad.dwt and place it in the template folder. It is then your startup template. I would also a copy of it with a distinctive name in the same template folder that way at any time you can change any template to your acad.dwt. If you use the same template for long periods of time it's a convenience to have it open on startup rather than have to do File, New and choose your template everytime that you want to open it.
  9. #9
    Forum Newbie
    AutoCAD 2007
    Oct 2009
    6
    Default how to put my designs of template in design center to crate my own tool palette
    thanks 4 your reply...can i ask you how to put my designs of template in design center to create my own tool palette?
  10. #10
    Forum Newbie
    AutoCAD 2007
    Oct 2009
    6
    examples of my templates are my own design of walls,doors,window,etc.
    how can i used it as startup templates,ill just copy/paste it from the a new drawing?
  1. scaling up an A1 template to an A0 template
    By treeman in forum AutoCAD Beginners' Area
    Last Post: 12th Mar 2008, 04:34 pm
  2. template
    By joewaianae in forum AutoCAD Beginners' Area
    Last Post: 28th Sep 2007, 03:43 pm
  3. Template
    By Starkey in forum AutoCAD Drawing Management & Output
    Last Post: 26th Feb 2007, 11:47 pm
  4. A4 Template
    By gw4100 in forum AutoCAD General
    Last Post: 26th Oct 2006, 10:17 am
  5. Drawing Template vs. Settings Template?
    By umop-3p!sdn in forum AutoCAD Beginners' Area
    Last Post: 20th May 2006, 01:09 am
