MR MAN Posted August 4, 2008 Share Posted August 4, 2008 When I Make Any Shape With Pline And Use The Command Planarsurface Then Click Inside That Shape The Area Inside Shape Divided Into Shapes Like 3dmeshes But Not Like 3dmesh In Its Properties . My Question Is How Can I Make Planarsurface Make 3dmesh? Quote Link to comment Share on other sites More sharing options...
papagyi Posted August 4, 2008 Share Posted August 4, 2008 YA!I have same wish you.I hope this will be next version. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 4, 2008 Share Posted August 4, 2008 Why do you want 3dmesh surfaces? Quote Link to comment Share on other sites More sharing options...
MR MAN Posted August 4, 2008 Author Share Posted August 4, 2008 I Want 3dmesh Because I Want To Import It In Sap2000(structural Program) Which Need 3dmesh To Analyes And It Not Accept Planarsurface Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 4, 2008 Share Posted August 4, 2008 What other file types will Sap2000 import. ACIS (*.sat) STEP or IGES? Quote Link to comment Share on other sites More sharing options...
MR MAN Posted August 5, 2008 Author Share Posted August 5, 2008 THE types will Sap2000 import ARE: 1- SAP2000 MS-ACCESS DATABASE .mbd FILES 2- SAP2000 MS-EXCEL SPREADSHEET .xls FILES 3- SAP2000 V8 OR V9 .s2k TEXT FILE 4- SAP 90 TEXT FILE 5- CIS/2 STEP FILE 6- AUTOCAD.DXF FILE 7- FRAMEWORKS PLUS FILE 8- IGES .igs FILE 9- NASTRAN .dat FILE 10- MODIFY STRUDL SECTION CUTS 11- PROSTEEL EXCHANGE DATABASE FILE THANKS, JD MATHER FOR YOUR CARE Quote Link to comment Share on other sites More sharing options...
MR MAN Posted August 7, 2008 Author Share Posted August 7, 2008 where are you jdmather any problem Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 7, 2008 Share Posted August 7, 2008 The only thing I can suggest is Autodesk Inventor Series. In the MDT module of AIS you can convert the AutoCAD surfaces. MDT or Inventor will output IGES or STEP. Actually you might be able to use the free Inventor LT (http://labs.autodesk.com) to open the file and save to IGES or STEP and try that in your other software. Quote Link to comment Share on other sites More sharing options...
MR MAN Posted August 8, 2008 Author Share Posted August 8, 2008 thank you jd mather for your advice Quote Link to comment Share on other sites More sharing options...
