Check out the tutorials in JD Mathers signature.
where can i find good *.idw tutorials? with much more detailed description and also with some tips & tricks.
Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
at the moment in one's personal UCS.
Go to PLAN view instead. - Dadgad
Do a google search for TEDCF
This is one of the best i have found it's for 2d autocad though, just saw that you areusing inventor..
http://www.andrew.cmu.edu/course/48-...iles/frame.htm
Also, the Jd Mathers one is good
Steven Smith
Solidworks - CSWP | AutoCad
Peak Scientific Instruments: Hydrogen, Nitrogen and Zero Air Generators
Ron Cheng has posted many parts from his book online. It's a great reference
http://acad-atc.ic.polyu.edu.hk/inventor/01intro.pdf
hope that helps
check TEDCF site they offer a lot of tutorial mediums there sheet metal, advance modeling ect. for 4 CD's it includes all you have to know... its good i buy whole set in movie format...
