+ Reply to Thread
Results 1 to 10 of 10
  1. #1
    Forum Newbie
    Using
    Civil 3D 2008
    Join Date
    Aug 2008
    Posts
    1
    Default Assigning selected objects to a layer
    We use Civil3D I am looking for a way to select one or more objects in a drawing and then assign them to a particual layer using a keyboard shortcut:
    i.e. a series of Cogo Points that I want to go on say a ground shot freeze layer by selecting the points and then typing Ctl+Shift+G
    Thanks
  2. #2
    Full Member shamsam1's Avatar
    Computer Details
    shamsam1's Computer Details
    Operating System:
    XP
    Using
    AutoCAD 2007
    Join Date
    May 2008
    Location
    Bangalore
    Posts
    85
    Default assigen material to layer
    http://www.cadtutor.net/forum/showth...color+to+layer
    cheek his thread hope this will help u
  3. #3
    Senior Member
    Using
    AutoCAD 2009
    Join Date
    May 2008
    Location
    Philadelphia, Pa.
    Posts
    407
    Default
    Were you looking for The LISP solution or VBA?
    ML
  4. #4
    Computer Details
    Operating System:
    XP
    Using
    AutoCAD 2007
    Join Date
    May 2008
    Location
    Bangalore
    Posts
    85
    Default both vba and lisp program will be helful
    Both vba nd lisp program will be helpful for attaching material to layer(object) for auto cad 2005/2006.
  5. #5
    Senior Member
    Using
    AutoCAD 2009
    Join Date
    May 2008
    Location
    Philadelphia, Pa.
    Posts
    407
    Default
    Hi shamsam1
    When you say materials, are you referring to blocks?
    ML
  6. #6
    Computer Details
    Operating System:
    XP
    Using
    AutoCAD 2007
    Join Date
    May 2008
    Location
    Bangalore
    Posts
    85
    Default
    when we type "rmat" in auto cad command we get material list there we can create name material also.there i can assign material to particular layer or object
    Quote Originally Posted by ML0940 View Post
    Hi shamsam1
    ML
  7. #7
    Senior Member
    Using
    AutoCAD 2009
    Join Date
    May 2008
    Location
    Philadelphia, Pa.
    Posts
    407
    Default
    Oh, I see
    You are doing rendering and mapping, correct?
    If so, I use to be really into that but I have never automated that process.
    ML
  8. #8
    Computer Details
    Operating System:
    XP
    Using
    AutoCAD 2007
    Join Date
    May 2008
    Location
    Bangalore
    Posts
    85
    Default
    yes i want to render it next after i assign the material.For autocad2007 i already have lisp to do that.but for auto cad 2005 its creating lot of problems
  9. #9
    Computer Details
    Operating System:
    XP
    Using
    AutoCAD 2007
    Join Date
    May 2008
    Location
    Bangalore
    Posts
    85
    Luck
    i got some thing here but still dont know how to proceed.
    http://discussion.autodesk.com/threa...sageID=5788336.
  10. #10
    Computer Details
    Operating System:
    XP
    Using
    AutoCAD 2007
    Join Date
    May 2008
    Location
    Bangalore
    Posts
    85
    Luck
    Help me Out guys ..to assign material to layer in autocad 2005/2006....Badly needed.
Similar Threads
  1. LISP for assigning layer color
    By ajl_mo in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Aug 2008, 12:30 pm
  2. Create new DWG from selected objects
    By MikeP in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Apr 2008, 11:11 pm
  3. Assigning materials to objects?
    By gordongxg in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Apr 2008, 11:56 am
  4. Get objects selected/VBA
    By Joro-- in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Feb 2008, 04:03 pm
  5. Assigning objects to layers
    By steve @ mp in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Aug 2006, 08:50 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
