Results 1 to 9 of 9
    Full Member
    AutoCAD LT 2009
    Aug 2008
    26
    Default Temporary Track Point vs Tracking
    I’ve been using Autocad LT since 1994 and the Tracking command has always worked the same, now in the newest version (2009) when I Shift + Right Click I only have “Temporary Track Point” on the menu and it works differently then the old Tracking in LT 2002.
    If I want to place a Point at a specific area inside a rectangle I would normally select Point then invoke Tracking then select the bottom left corner of the rectangle and move the cursor over to the Right and enter a distance such as 2.1 Enter, then move my cursor up and enter another distance 2.5 Enter, Enter. That would place the point at 2.1,2.5 relative to the lower left corner of the rectangle. I can no longer do this because as soon as I hit Enter after the first distance it places the point there.
    This is the command I use the most and I can’t figure out how to do the same thing in the newer version, can anyone help?
    What am I doing wrong?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,052
    Courtesy of AutoDe$k:
    "The direct distance entry method is not available while you are using the temporary override keys for Ortho mode, object snap tracking, or polar tracking."
    Full Member
    AutoCAD LT 2009
    Aug 2008
    26
    So I cant do that anymore?
    Why would they take away such a useful command, isnt that going backwards?
    How do you guys place a point at a specific place inside a polygon?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,052
    No, you CAN do it. Shift-Right click still works. Just look at your User's Guide or Help.
  5. #5
    Full Member
    AutoCAD LT 2009
    Aug 2008
    26
    There is no Tracking command from the shortcut menu anymore, it was there in LT 2002 but not here in LT 2009.
    I have found out that I can type in the "Tracking" or "TK" or "Track" command in the command window after involking a Line or point command and it will work, but I would like to get that into the shortcut menu just above Temporary Track Point. Does anyone know what the Properties of this command are?
    I cannot find Tracking in the command list in the CUI. I can make a custom command but I dont know all the properties to make it work.
  6. #6
    Full Member
    AutoCAD LT 2009
    Aug 2008
    26
    Figured it out, now I can make a contribution to the forum.
    For those who use the older Tracking command from the shortcut menu and miss the inclusion in LT2004 and up you can add it in the CUI by making a custom command and naming it Tracking and putting “_tracking” next to the Macro space in Properties, then add by dragging to the CUI “Shortcut Menus/Object Snap Cursor Menu”
    Screen shot below to help.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,052
    Please send AutoDe$k a big "thank you" for screwing things up. It seems some geek programmer gets to decide what is and isn't useful in the "real world". Go figure.
    Thank you for sharing the fix with us.
  8. #8
    Senior Member soleary's Avatar
    soleary's Computer Details
    Windows Vista
    AutoCAD 2008
    Oct 2008
    Ireland, Republic of
    202
    Wink
    Although the 2008 user guide says that tracking is available on the shift right-click menu, it is not avaialble. It has to be added as pointed out above
  9. #9
    Forum Newbie
    Architecture 2012
    Oct 2011
    1
    Thank you Kingdaddy!!! So happy I have that command on my shortcut menu now. I did add it to 2008 back when, but I forgot how. Upgraded to 2012 and was really missing it. I am all set now--at least with this issue. Need to set up plots and pen assignments tomorrow. Ugh.
  1. osnap tracking: second tracking line?
    By butterblume in forum AutoCAD Beginners' Area
    Last Post: 10th Sep 2007, 04:09 pm
  2. Storage location of temporary render images
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 2nd Feb 2007, 02:14 am
  3. Avoid drawing temporary construction lines
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 29th Sep 2006, 04:15 am
  4. Temporary Osnap feature
    By Cadkiller in forum AutoCAD Drawing Management & Output
    Last Post: 9th Apr 2006, 07:02 pm
