Try Erase > All > Remove > {window the elements you want to keep}
and/or try this
Code:; Delete Null Objects ;; DelNul.lsp ;; Deletes nul lines of Text, Mtext & Blocks. ;; Modified by JL Thomas 12/02/97 (Defun C:DelNul ( / TXT BLK NB NAMES) (if(setq TXT (ssget "X" '((-4 . "<and")(-4 . "<or") (0 . "MTEXT")(0 . "TEXT") (-4 . "or>")(-4 . "<or") (1 . "")(1 . " ")(1 . " ")(1 . " ") (1 . "{}")(1 . "{ }")(1 . "{ }")(1 . "{ }") (1 . "{}\P")(1 . "{ }\P")(1 . "{ }\P")(1 . "{ }\P") (-4 . "or>")(-4 . "and>")))) (progn (command"_erase"TXT"") (princ(strcat"\n "(itoa(sslength TXT))" nul text strings deleted. ")) ) (princ"\n No nul text strings found. ")) (setq BLK(tblnext"BLOCK"T)NAMES nil) (while BLK (if(=(cdr(assoc 0(entget(cdr(assoc -2 BLK)))))"ENDBLK") (progn (if(setq NB(ssget "X" (list(assoc 2 BLK)))) (command"_erase"NB"") ) (setq NAMES(cons(cdr(assoc 2 BLK))NAMES)) ) ) (setq BLK(tblnext"BLOCK")) ) (if NAMES (progn(textscr) (princ"\n Nul blocks found and need purging: ") (foreach X NAMES(princ"\n ")(princ X)) ) (princ"\n No nul blocks found. ") ) (princ) ) (c:DelNul)
