+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Aug 2008
    Posts
    2
    Default Any command in Autocad that behaves like Visio Line Connector?
    Hi, i am not an incredibly advanced user but i know a bit.
    I have Autocad 2008 , and Autocad 2004 LT.
    Answering the question for either one would be great, also considering upgrading to 2009, so if that has relevance...
    Basically doing some basic wiring stuff and was wondering if there is any command that behaves like Visio Line Connector tool. (Microsoft Visio)
    (i.e. line jumps, auto routing, and click points)
    If there is a way to get that same behavior with an Autocad line, i would love to know.
    Thanks.
  2. #2
    Super Member rustysilo's Avatar
    Computer Details
    rustysilo's Computer Details
    Operating System:
    WinXP
    Discipline
    Civil
    rustysilo's Discipline Details
    Occupation
    Senior CAD Draftsman
    Discipline
    Civil
    Using
    Civil 3D 2008
    Join Date
    Jul 2007
    Location
    Jacksonville, FL - USA
    Posts
    1,458
    Default
    Perhaps you should explain what you are trying to accomplish. The more info you give the quicker you will get answers.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
  3. #3
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Aug 2008
    Posts
    2
    Default
    very basic electrical wiring...
    if anyone has used visio, they have the line connector tool.
    there are click points that you can click from one to the next...
    when you do that it auto draws a "path" from the first point to the second point.
    if there is another line connector in the way it will automatically "jump" the other line connector.
    i am not sure if there is a way to make a line that behaves this way in Autocad, and i was just hoping someone else would know.
    i don't know if that clarifies what i mean at all?
  4. #4
    Full Member acemasi's Avatar
    Using
    Civil 3D 2008
    Join Date
    Oct 2006
    Location
    Fiji
    Posts
    57
    Default
    You might have to write up a lisp routine on this. I don't think that works in CAD. It will be great to have this on CAD. Makes Life Easier. I've experience Visio and its great when you are drawing a line and it automatically jump over a crossing line creating semi-circle above it when approaching.
  5. #5
    Junior Member
    Using
    Building Systems 2008
    Join Date
    Nov 2007
    Posts
    16
    Default
    Set SNAP to a value that makes sense for what you are working on. Also use OSNAPs to snap to the end point, mid point of lines, etc.
Similar Threads
  1. AutoCAD to Visio
    By LElkins in forum AutoCAD Drawing Management & Output
    Last Post: 12th Feb 2008, 10:26 am
  2. Command line issue with AutoCad
    By cadtutoraccount in forum AutoCAD Drawing Management & Output
    Last Post: 14th Dec 2007, 12:35 am
  3. Command Line on/off - AutoCAD 2004
    By Jaxom in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2007, 08:06 pm
  4. AutoCad command line on specify next point
    By Otaku Ichise in forum AutoCAD Beginners' Area
    Last Post: 4th Jan 2007, 02:18 pm
  5. AutoCAD LT Tables/Command Line
    By noochstyle in forum AutoCAD General
    Last Post: 29th Nov 2006, 02:04 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
