Wide line
ylind
some time ago I had a Toolbar button that would allow me to pick a LINE, Change it to a polyline and change it to a set width.
Something like this; (Command: pedit "y" "w" "0.5")
but this don't work. Can anyone help? A lisp routine might also work.
T.I.A.
y.L
here, this is a real simple routine i use to quickly join plines, lines, arcs.
i modified it to set the width instead of joining. you can change the title, and whatever else you don't like.
;join multiple lines/arcs
;created: alan thompson, 4.23.08
;modified: alan thompson, 5.13.08 (localized variables to stop being so sloppy)
(defun c:mj(/ lines)
(princ "\nSelect lines & arcs to JOIN: ")
(setq lines (ssget '((0 . "*LINE,ARC"))))
(if lines
(if
(equal (getvar 'peditaccept) 1)
(command "pedit" "m" lines "" "w" "0.5" "")
(command "pedit" "m" lines "" "y" "w" "0.5" "")
);if
);progn
(alert (strcat "\nHey " (getvar "loginname") " it helps if you actually select something to work with!"))
);if
