Sum of numbers in text strings
mikman
I was recently using a lisp that added up text and created a text string with the sum. It stopped working and quoted the function "mktext" as the problem. It will still add the strings but it will not create a new string. I can't modify the routine, its locked and the owner doesn't work with me anymore. :( /:D Where can I find a place that would have a lisp that I could read and learn for myself?
Here is a quick example, hope this helps
(defun C:STX (/ elist en ss sum sumtxt txt)
(princ "\n\t\t>>>  Select text to get summ >>>")
(if
;;select texts/mtexts on screen :
(setq ss (ssget '((0 . "*TEXT"))))
;; if selected then :
 ;; set initial sum to zero :
 (setq sum 0.)
 ;; loop trough selected texts/mtexts :
 (while
   ;; get the first text in selection :
   (setq en (ssname ss 0))
   ;; get entity list of them :
   (setq elist (entget en))
   ;; get the textstring by key 1 from entity list :
   (setq txt (cdr (assoc 1 elist)))
   ;; create output string :
   (setq sumtxt
   ;; concatenate strings :
   (strcat
     ;; convert digits to string :
     (rtos
       ;; add to summ the digital value of text :
       (setq sum (+ (atof txt) sum))
       ;; 2 is for metric units (3 for engineering) :
       2
       ;; set precision by current :
       (getvar "dimdec")))
   ;; delete entity from selection set :
   (ssdel en ss)
 ;; display message :
 (alert (strcat "\nSumm = " sumtxt))
(princ "\nStart command with STX...")
Sorry for my poor english :)
~'J'~
That works pretty good Fixo. At this point where the window pops up with the number, do you know how to make a new text string? You are miles ahead of me so I hope you can help?
Do not agreed with you
The Earth is so small, take a look on map -
just 5-6 thousand of miles or so :)
Here is edited version
This will create the new text entity with
the same properties as the first selected
text has
(defun C:STX (/ cpent elist en ip newtxt pt ss sum sumtxt txt)
(if
 ;; store the first text entity for using 'em further :
(setq cpent (ssname ss 0))
 (setq sum 0.)
 (while
   (setq sumtxt
   (strcat
     (rtos
       2
       (getvar "dimdec")))
   (ssdel en ss)
 ;; display message in the command line:
 (princ (strcat "\nSumm=" sumtxt))
 (setq pt (getpoint "\nSpecify the new text location: "))
 ;; get the insertion point of stored entity :
 (setq ip (cdr (assoc 10 (entget cpent))))
 ;; copy text entity to the new destination point :
 (command "_copy" cpent "" ip pt)
 ;; get the last created entity :
 (setq newtxt (entlast))
 (setq elist (entget newtxt))
 ;; modify entity list with new text string :
 (entmod (subst (cons 1 sumtxt)(assoc 1 elist) elist))
 ;; update changes :
 (entupd newtxt)
~'J'~
  • 1 year later...
hi!
i'm using this lisp but if it's possible i want an addition.
i want to sum texts with unit. for example:
i will select: 1, 2, and 3
it sums and creates a text which is: 6 m³/h or 6 Watt etc.
how can i do this?
(if
 (setq sum 0.)
 (while
   (setq sumtxt
   (strcat
     (rtos
       2
       (getvar "dimdec")))
   (ssdel en ss)
~'J'~
Look near the end of the code for
and replace the line below with
 (setq ins (getpoint "\nSpecify text location: "))
 (entmake (list (cons 0 "text")
                    (cons 1 (strcat sumtxt "m3/h"));;text
                    (cons 7 "ROMANS");;text style
                    (cons 8 "acc");;textlayer
                    (cons 10 ins);;insertion point
                    (cons 11 ins)
                    (cons 40 2);;text height
                    (cons 62 256);;bylayer
                    (cons 72 1);;horizontal justification
and replace
       2
with 5
by the way great routine fixo!
Why not put your name on it fixo?
Edited by Lt Dan's legs
additional info and question to fixo
i'm sorry i couldn't make it. i changed the (setq ins ... code with your code but, it did not work. Could you add the whole code please? I will really appreciate it.
-i saw your changed message after my post sorry.
-yes i didn't want to see decimal part, so i changed "2" with so many numbers and catch the 5 (by luck) :D
-sorry for my poor English.
(defun C:STX (/ elist en ss sum sumtxt txt ins)
;;created by Fixo
;;revised by Reid B. for sanalmakina
(if
 (setq sum 0.)
 (while
   (setq sumtxt
   (strcat
     (rtos
       5;;revised by Reid B.
       (getvar "dimdec")))
   (ssdel en ss)
 ;; Change to text :
   (setq ins (getpoint "\nSpecify text location: "));;start revision by Reid B.
 (entmake (list '(0 . "text")
                    (cons 100 "AcDbEntity")
                    (cons 100 "AcDbText")
                    (cons 11 ins)
                    (cons 41 1);;text width
                    (cons 50 0);;text rotation
                    (cons 72 0);;horizontal justification
             );;end revision by Reid B.
;;created by Fixo
(if
 (setq sum 0.)
 (while
   (setq sumtxt
   (strcat
     (rtos
       (getvar "dimdec")))
   (ssdel en ss)
 ;; Change to text :
                    (cons 11 ins)
Thank you Lt Dan's legs but, it doesn't work for me :s when i clicked for insertation, nothing happened.
if I understand the OP correctly, you can simplify the deal:
[color=#8b4513];;;Given a true numeric string list[/color]
 [b][color=BLACK]([/color][/b]setq s1 [color=#2f4f4f]"3.4 5.6 7 8. 9"[/color][b][color=BLACK])[/color][/b]
[color=#8b4513];;;Format the string into an autolisp funtion[/color]
 [b][color=BLACK]([/color][/b]setq as [b][color=FUCHSIA]([/color][/b]strcat [color=#2f4f4f]"[b][color=NAVY]([/color][/b]+ "[/color] s1 [color=#2f4f4f]"[b][color=NAVY])[/color][/b]"[/color][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
[color=#8b4513];;;Evaluate the string[/color]
 [b][color=BLACK]([/color][/b]setq av [b][color=FUCHSIA]([/color][/b]eval [b][color=NAVY]([/color][/b]read as[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
[color=#8b4513];;;Contevrt the results into a string[/color]
 [b][color=BLACK]([/color][/b]setq ar [b][color=FUCHSIA]([/color][/b]rtos av[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
[color=#8b4513];;;Print the results[/color]
 [b][color=BLACK]([/color][/b]princ ar[b][color=BLACK])[/color][/b]
-David
I think he means the following adds to meet his desire...
;;created by Fixo
(if
 (setq sum 0.)
 (while
   (setq sumtxt
   (strcat
     (rtos
       (getvar "dimdec"))" " [color="red"]"m3/h"[/color])
   (ssdel en ss)
 ;; Change to text :
 (command "_.text" ins "" "" sumtxt)
;;created by Fixo
(if
 (setq sum 0.)
 (while
   (setq sumtxt
   (strcat
     (rtos
       (getvar "dimdec")))
   (ssdel en ss)
 ;; Change to text :
                    (cons 11 ins)
i tried but it didn't work :(. command text:
Command: appload
asd.lsp successfully loaded.
Command:
Command:
Command:
Command: text
Current text style: "K2000Style" Text height: 0.1000 Annotative: No
Specify start point of text or [Justify/Style]:
Specify rotation angle of text :
Command: Specify opposite corner:
Command: c COPY 1 found
Current settings: Copy mode = Multiple
Specify base point or [Displacement/mOde] : Specify second point
or :
Specify second point or [Exit/Undo] : *Cancel*
Command: stx
Select objects: 1 found
Select objects: 1 found' date=' 2 total
Select objects:
Specify text location:[/quote']
;;created by Fixo
(if
 (setq sum 0.)
 (while
   (setq sumtxt
   (strcat
     (rtos
   (ssdel en ss)
 ;; Change to text :
it writes it to command bar, not to the drawing:(.
command text:
Command:
or :
Command: stx
Select objects: 1 found, 2 total
Select objects:
Specify text location: _.text
Enter text:
Command: 246246 m3/h Unknown command "246246 M3/H". Press F1 for help.
Command:
You are relying on this textstyle actually existing.
Replace with
(cons 7 (getvar 'textstyle))
The problem is with the Text Style which is current , I mean put the Text height for it zero and try again.
No, use entmake. Text in command is the most temperamental function that can be called.
