Find points connected with line or polyline
Bane
Hello everybody,
I use ssget function to select all point entities in drawing. I need some kind of filter to select only those points which represents a starting or ending point of existing line or polyline. Other (free) points should be excluded from selection set.
Any help is very welcome.
Thank you
Give that a try
Not tested enough
;; local defun
(defun _remove-points(/ en i pe pt sscol ssl ssp)
(setq sscol (ssadd))
(setq ssp (ssget "_X" (list
	       (cons 0 "POINT")
               (cons 410 (getvar "CTAB")))))
(setq i -1)
(while (setq en (ssname ssp (setq i (1+ i))))
      (setq pt (cdr (assoc 10 (entget en))))
 (if  (setq ssl (ssget "C" (list (car pt)(cadr pt))
		(list
		  (cons 0 "LINE,*POLYLINE")
     (setq pe (ssname ssl 0))
     (if (or
    (equal (vlax-curve-getclosestpointto pe pt)
		   (vlax-curve-getstartpoint pe) 0.00001)
		  (vlax-curve-getendpoint pe) 0.00001))
(ssadd en sscol); gather the desired points into separate selection set
sscol ;<-- return selection set with desired points
;; usage:
(defun C:test ()
 (setq ss (_remove-points))
 (alert (strcat "Desired points found: " (itoa (sslength ss))))
(vl-load-com)
~'J'~
Sorry, I forgot to add this line:
(vl-load-com)
this function load ActiveX DLLs (VLA-functions)
I edited my code above, try it again
BTW, tested on A2008 only
~'J'~
That's it. Thank you.
There is only one more problem, but probably, it is AutoCads' bug. I finished this code by inserting circles on points in new selection set. If I zoom "extents" some points that should have circle on it are omitted. If I zoom "in" to that points and start this code again, everything is ok.
I can live with this.
Thank you for help.
Best wishes.
Hope an addition will be fix this problem:
(defun C:test ()
(command "._zoom" "_e")
(command "._zoom" "_p")
~'J'~
I already tried something similar. In my current drawing there are 2 points which must be selected in selection set because they represent starting points of two lines. But when I start this code they are not selected. Only if I zoom in more enough to see clearly that two points, everything is ok.
Maybe it is important to notice that third line passes very close to that points (about 2mm).
I can send an example, if you want.
Thanks.
(defun C:test ()
~'J'~
I think you need to set OSMODE to 0 before
you'll draw circles in these points
Okay, upload your drawing to see where is
a problem
~'J'~
Autocad has a nasty habit of snapping the wrong object when using lisp etc its usually a good idea to turn your osmode to 0 and reset it (setvar "osmode" myosmode) at the end of your code.
Also another bug I came across similar problem for a lisp to work I had to zoom in to a reasonable viewing scale, in close fine, too far out would not work! Used first pick then zoomed scale before next pick point.
Here is another method, not as fast though.
(defun find-points (/ en i pt result ssl ssp EndPoints TmpLst1 TmpLst2)
 (vl-load-com)
                  (list
                    (cons 0 "POINT")
 (setq ssl (ssget "_X"
                  (list
 ;;  get all endpoints from Lines & Polylines
 (setq i -1)
 (while (setq en (ssname ssl (setq i (1+ i))))
   (setq EndPoints (cons (vlax-curve-getstartpoint en) EndPoints)
         EndPoints (cons (vlax-curve-getendpoint en) EndPoints)
 ;;  Loop through All points, find any matching end points
 (setq i -1)
   (setq TmpLst1 EndPoints
         TmpLst2 nil
   (While ; loop through All Line endpoints, remove any matches
     (and EndPoints
          (setq p (car TmpLst1))
          (if (equal (distance pt p) 0.0 0.00001)
            (progn ; got a matching point
              (setq result (cons en result)) ; gather points into a list
              (setq Endpoints (append (reverse TmpLst2) (cdr TmpLst1)))
              nil ; Exit While Loop
            (setq TmpLst2 (cons p TmpLst2)
                  TmpLst1 (cdr TmpLst1)) ; not a match, stay in loop
 result   ; <-- return list with desired points
;; usage:
(defun C:test (/ lst)
 (if (setq lst (find-points))
   (alert (strcat "Desired points found: " (itoa (length lst))))
   (alert "No points found: ")
