Results 1 to 8 of 8
    Forum Newbie
    not specified
    Mar 2005
    6
    Default Non-Coplanar polylines
    In AUTOCAD, I would like to JOIN two non-coplanar
    (drawn in different UCS) POLYLINES - how can I
    do it? I would like to use it as a path to EXTRUDE
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    Welcome Uzmazain!
    While the two polylines are on the screen set the OSNAP to
    END points and start the 3DPOLY command. Click the
    existing points in order to create the new 3D polyline.
    When done you may delete the initial polylines.
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Forum Newbie
    not specified
    Mar 2005
    6
    thanks for the advise
    Senior Member
    not specified
    Mar 2005
    208
    Another option would be to change the UCS to
    the plane through which you want to extrude
    and draw the Plines on that plane.
    If there is anything the nonconformist hates worse than a conformist,
    it's another nonconformist who doesn't conform
    to the prevailing standard of nonconformity.
  5. #5
    Super Member Mr T's Avatar
    AutoCAD 2007
    Nov 2002
    Loch Oich SCOTLAND...
    1,640
    Quote Originally Posted by Big Mike
    to change the UCS to the plane through
    which you want to extrude and draw the
    The idea behind 3DPOLY lines is to avoid that.
    Nick
    http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
    http://s240.photobucket.com/albums/ff241/dyNick_Scots/
    http://designgraphicsshowcase.blogspot.com/
    High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
    Home - AMD 2.1GHZ - 512Ram, 64 Video,
    Laptop Inventor 7, Autocad 2004, Corel 11
  6. #6
    Senior Member
    not specified
    Mar 2005
    208
    That's true, but it helps to understand the theory of setting & rotating the UCS.
  7. #7
    Senior Member erona's Avatar
    Architectural
    erona's Discipline Details
    Architect
    Architectural
    AutoCAD 2013
    Feb 2005
    Philippines
    306
    I agree. Its a big thing when you get a grip on rotating
    UCS especially when dealing with 3D objects. I'm a
    big fan when it comes to rotating the UCS.
    erona
  8. #8
    AutoCAD 2007
    Nov 2002
    1,640
    But you can do a lot BEFORE that bridge.
    See here.
    http://www.eezylearn.pwp.blueyonder...._n_revolve.htm
    Nick
