Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Junior Member
    AutoCAD 2010
    Aug 2008
    Viet Nam
    11
    Default about load CUI file
    Hi all,
    I have a CUI file include toolbar and menu with name mycuifile.cui, when i use a scrip file with command
    (command "_menuload" "C:\\mycuifile.cui")
    Autocad load toolbar only, it can't load menu
    why?
    thanks for support!
    Super Member ASMI's Avatar
    AutoCAD 2008
    Nov 2005
    Oceanus Procellarum, Moon
    1,427
    (command "_cuiload" "C:\\mycuifile.cui")
    Junior Member
    AutoCAD 2010
    Aug 2008
    Viet Nam
    11
    thanks but it can't load menu, too.
    But when i type (command "_menuload" "C:\\mycuifile.cui") in command line, it work correct
    Autocad load toolbar and menu
    Senior Member wizman's Avatar
    AutoCAD 2009
    Nov 2007
    Abu Dhabi / Philippines
    408
    you may try this one.
    Code:
    (defun c:loadit	(/ cui_database mnbar flag)
      (vl-load-com)
      (setq	cui_database
    	 (list
    	   "EXPRESS"			;<<< MENUGROUP
    	   "C:\\Documents and Settings\\Ronald\\Application Data\\Autodesk\\AutoCAD 2008\\R17.1\\enu\\support\\acetmain.cui" ;<<<PATH & CUI FILENAME
    	   "E&xpress"			;<<< MENUNAME
    ) ;_ end_list
      ) ;_ end_setq
      (vlax-for n
    	      (setq all_menus
    		     (vla-get-MenuGroups
    		       (vlax-get-Acad-Object)
    		     ) ;_ end_vla-get-MenuGroups
    	      ) ;_ end_setq
        (if	(= (vla-get-name n) (car cui_database))
          (setq flag T)
        ) ;_ end_if
      ) ;_ end_vlax-for
      (if (null flag)
          (vla-load
    	all_menus
    	(cadr cui_database)
          ) ;_ end_vla-load
          (setq MnBar
    	     (vla-get-MenuBar
    	     ) ;_ end_vla-get-MenuBar
          ) ;_ end_setq
          (vla-InsertInMenuBar
    	(vla-Item
    	  (vla-get-Menus
    	    (vla-Item
    	      (vla-get-MenuGroups
    	      (car cui_database)
    	    ) ;_ end_vla-Item
    	  ) ;_ end_vla-get-Menus
    	  (caddr cui_database)
    	) ;_ end_vla-Item
    	(1- (vla-get-Count MnBar))
          ) ;_ end_vla-InsertInMenuBar
        ) ;_ end_progn
        (princ "\n>>..MENU IS ALREADY LOADED..<<")
      ) ;_ end_if
    ) ;_ end_defun
  5. #5
    Junior Member
    AutoCAD 2010
    Aug 2008
    Viet Nam
    11
    Thanks for your support, it work correctly. But I want to use scrip file to add my menu and toolbar in Cad on another PC. That cui file is a share file.
    Can you help me? Thanks!
  6. #6
    AutoCAD 2009
    Nov 2007
    408
    in your scr file, you may have this:
    ;;;Point the script to the location of the loadit.lsp
    (load "c:\\completepathhere\\loadit)
    ;;;then run
    (c:loadit)
    you may also need to add additional support paths for your menu to work correctly in another computer.
  7. #7
    Junior Member
    AutoCAD 2010
    Aug 2008
    Viet Nam
    11
    i think so, thanks for your support!
  8. #8
    Junior Member
    AutoCAD 2010
    Aug 2008
    Viet Nam
    11
    When i use command cuiunload in my scrip to unload my cui file, it's only unload menu and toolbar on screen. partial cui file in CUI interface is not unload. when i restart ACAD it show toolbar again. Why?
    Thanks for support.
  9. #9
    AutoCAD 2009
    Nov 2007
    408
    try this:
    Code:
    (defun c:unloadit ()
    (vl-load-com)
    (vla-unload (vla-Item (vla-get-MenuGroups (vlax-get-Acad-Object)) "EXPRESS")) ;...<<< MENUGROUP
    ) ;_ end_defun
  10. #10
    Junior Member
    AutoCAD 2010
    Aug 2008
    Viet Nam
    11
    Thanks, but it used like command "cuiunload" cui file in CUI dialog is still there
  1. Anyway to Re-Load & Un-Load Xrefs by Picking?
    By pjb84 in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Aug 2007, 09:39 pm
  2. load
    By rookie37 in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Mar 2007, 11:45 pm
  3. Help!!! My default acad.mnl file doesn't auto load!
    By greg.wright1 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Feb 2007, 01:57 pm
  4. always load some linetypes
    By paotis in forum AutoCAD General
    Last Post: 27th Nov 2006, 07:47 am
  5. I want to load block from file [vba]
    By pefi in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Aug 2006, 08:58 am
