there are different versions for 64 bit. I think you need to go back to your retailer.
So i just got my new Sager which has Vista Ultimate 64-bit. Went to install AutoCAD 2009 and it told me that it cannot be installed on that OS. Hmmmm.
Nathan Scherneck,
NICET III, Fire Alarm
NICET I, Special Hazards
NICET I, Automatic Fire Sprinkler Layout
Electrical / Low Voltage Systems Design (Safeway Security Systems - Colton, CA)
"That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
Dave
First. Check out AutoCAD 2009 System Requirements.
http://autodesk.blogs.com/between_th...d-2009-sy.html
So i assume that the installer i have is for 32-bit version? Is there any way to make it work for the 64-bit version?
Nathan Scherneck,
During the installation of AutoCAD 2009 you are presented with a screen listing the following choices:
-Read the Documentation
-Install the Products
-Create Deployments
-Install Tools & Utilities
I suggest you look under Read the Documentation and locate the following section:
Install AutoDesk products for an individual user.
Notice what is written under the following section:
System Requirements
It states:
"Before you install your product on a standalone computer, make sure your computer meets the standard minimum requirements.
Whether the Windows operating system is 32-bit or the 64-bit version is automatically detected when installing AutoCAD. The appropriate version of AutoCAD will be installed. The 32-bit version of Auto cannot be installed on a 64-bit version of Windows."
If you are using an installer disk then you must be installing multiple products. If this so?
There is a workaround that allows you to install 32bit autocad on a 64 bit OS
Here's the link
http://discussion.autodesk.com/thread.jspa?threadID=562426
