Polly Posted August 27, 2008 Share Posted August 27, 2008 I use copy with base point to copy the block from one drawing and paste it on the other drawing. I can't not use osnap (near to, or apparent intersection) with that copied block. Anyone has any idea on how to fix this problem? Thank you. Quote Link to comment Share on other sites More sharing options...
GE13579 Posted August 28, 2008 Share Posted August 28, 2008 Has it anything to do with the layer you have inserted the block on? Quote Link to comment Share on other sites More sharing options...
Polly Posted August 28, 2008 Author Share Posted August 28, 2008 What do you mean? But I don't think so because if I draw an object I can use osnap of any kind without any problem. Thank you for your reply. Quote Link to comment Share on other sites More sharing options...
GE13579 Posted August 28, 2008 Share Posted August 28, 2008 Can you post the block at all? Quote Link to comment Share on other sites More sharing options...
Polly Posted August 28, 2008 Author Share Posted August 28, 2008 Do you want me to post the block on this forum? If I insert the block directly to the drawing I have no problem with osnap, but if I copy that block from one drawing and paste it on to the other drawing I will have problem specially with near to, or app to. I can snap to end of or center of. Quote Link to comment Share on other sites More sharing options...
GE13579 Posted August 28, 2008 Share Posted August 28, 2008 Is the block inserted on z=0? Maybe check the properties... If you can post the block, then I will emulate the problem, but please save down to 2006 as I can't open 2008. Quote Link to comment Share on other sites More sharing options...
Polly Posted August 28, 2008 Author Share Posted August 28, 2008 Here's the block. z=0 and I still can't snap to the circle or the triangle area with nea to. I save down to 2004 I hope you can open it. signal-head.dwg Quote Link to comment Share on other sites More sharing options...
GE13579 Posted August 28, 2008 Share Posted August 28, 2008 Ok... I have the same problem as you, but if I BEDIT and save the block as whatever, when I insert the new block it comes in much smaller than yours, and snap to nearest works fine on the triangle and circle. I'm not sure what the issue is though and I'm afraid I'm away for the weekend from this evening so hopefully someone else can help, but does the block need to be so small in the first instance? Quote Link to comment Share on other sites More sharing options...
rkent Posted August 28, 2008 Share Posted August 28, 2008 use lines and circles in the block instead of plines as a work around Quote Link to comment Share on other sites More sharing options...
Polly Posted August 28, 2008 Author Share Posted August 28, 2008 Just like I told you if I inserted in the drawing I have no problem. The problem occurred when I use copy with base point and copy from drawing A and insert to drawing B. Thanks for your help and have a greate long weekend. Quote Link to comment Share on other sites More sharing options...
Polly Posted August 28, 2008 Author Share Posted August 28, 2008 rkent, do you think the pline will creat this kind of problem? Quote Link to comment Share on other sites More sharing options...
GE13579 Posted August 28, 2008 Share Posted August 28, 2008 I have no problem with _copybase to another drawing, the only problem for me (I think?) is that the original has been scaled up so much?? Quote Link to comment Share on other sites More sharing options...
BOB'27T Posted August 28, 2008 Share Posted August 28, 2008 I had the problem when I tried to edit it. If I did a block edit, it snapped to everything perfectly. Now when I scaled it down to 1 instead of 20, I had no problem with snaps. Also the ltscale is too large. I would suggest scaling it down, do the changes, the resize it. Quote Link to comment Share on other sites More sharing options...
Polly Posted August 28, 2008 Author Share Posted August 28, 2008 I think it's just that one block, bad block. Thanks everybody! Quote Link to comment Share on other sites More sharing options...
rkent Posted August 28, 2008 Share Posted August 28, 2008 There are various problems with plines and osnaps, I know it has been real bad in 2009 but I think I remember problems in 08 as well. Quote Link to comment Share on other sites More sharing options...
Polly Posted August 28, 2008 Author Share Posted August 28, 2008 Thanks. I need to revise that block. Quote Link to comment Share on other sites More sharing options...
khama Posted September 3, 2008 Share Posted September 3, 2008 Well I can't help you either. I downloaded the file and got every snap without a problem as a block. Gee even nearest works on every point of every line and shape. I don't know. No problems here. Quote Link to comment Share on other sites More sharing options...
skipsophrenic Posted September 3, 2008 Share Posted September 3, 2008 i'll have a look when get home tonight Quote Link to comment Share on other sites More sharing options...
Polly Posted September 3, 2008 Author Share Posted September 3, 2008 Khama, try copy with basepoint and paste it because I have the problem when I do that. I have no problem with the block itself if I insert it (not copy from other drawing). Thanks for your time to look into this thread. Quote Link to comment Share on other sites More sharing options...
LAD152 Posted September 3, 2008 Share Posted September 3, 2008 Try exploding the block. Type explode in the command line...select the block and select enter. Now try using osnap. Now it's not just one entity, every line is a single entity. Quote Link to comment Share on other sites More sharing options...
