LISP for Errors...
Lee Mac
I have written an AutoLISP routine, (see below), but would like to insert a few lines to cope with errors, (such as if the user presses 'Esc' halfway through - the Osnap settings are all still turned off and have to be put back on manually).
The LISP is used to insert a block (a valve on a P&ID) which has an attribute which is the valve number.
Another issue I am having is that AutoCAD 2004 will not let me run another LISP similar to the one posted and allow me to insert a different block - it will just insert the same block all the time.... Any ideas?
INSBLOCKGATE2.lsp
