Results 1 to 6 of 6
    Senior Member
    AutoCAD 2006
    Jan 2008
    Dartmoor, Devon, UK
    192
    Default Unreliable SU6 (free)
    I gave up on SketchUp - maybe time to try again. Does anyone else have the trouble I had? I found SU6 (free) hopelessly unreliable at uniting lines drawn colinear and that had many effects like areas not closing as surfaces; never sure what I'd selected. Even with continual use of Plug-ins Make Faces and Stray Lines, I spent so much time chasing faults. Someone told me that's typical of SU on a PC but happens not at all on a Mac - that's hard to believe.
    Super Member CADken's Avatar
    CADken's Computer Details
    Microsoft Windows 7 Ultimate
    Toshiba Satellite A135
    Intel Pentium T2080 @ 1.73GHz, 1733 Mhz, 2 Core(s), 2 Logical Processor(s)
    Slot 1: 1GB DDR Slot 2: 1GB DDR
    Toshiba 110GB, Maxtor External HD 120GB
    Notebook Monitor + 22" NEC AccuSync LCD223wxm
    AutoCAD 2010
    Jun 2006
    East Coast - Pennsylvania
    828
    not sure what OS you have, but Vista and SU were known to have some common issues that can easily be resolved.
    It sounds like you may have had a driver issue.
    Post your computer specs.
    Fireman | Draftsman | Fabricator
    Running Windows 7 with AutoCAD 2010
    the Battalion East Side Pride
    Senior Member
    AutoCAD 2006
    Jan 2008
    Dartmoor, Devon, UK
    192
    OK - XPHome, AMD ATHLON 64 x2 3600 GHz, 4GB PC3200 400MHz, GIGABYTE K8N-SLI ATX BOARD, GEFORCE 6800GS, 500GB SATA 8MB CACHE 7200 RPM (sorry, caps as copied from the spec/invoice). Logitech wireless kbd and mouse, 3DConnexions SpacePilot. Any good?
    Full Member 97catintenn's Avatar
    Construction
    97catintenn's Discipline Details
    Small Construction
    Construction
    Architecture 2013
    Oct 2007
    Johnson City, TN USA
    85
    Your specs are more than enough for SU. As for your surfaces not closing in (or areas not closing in), that happens to me all the time.
    I have to keep to flipping the picture around so that the program will fill in the surface for me, so that I can then cover it with whatever material I want.
    I think it's just something that takes getting used to.
    Matt
    Licensed General Contractor
    www.outdoorliving.ws
  5. #5
    Senior Member
    AutoCAD 2006
    Jan 2008
    Dartmoor, Devon, UK
    192
    Thanks for reply. By 'flipping' you mean pan/zoom/rotate? - and that causes recalculation? I don't find that - and I'd have said that was just a graphics/presentation change, wouldn't cause recalc of the underlying database? Still, if it works for you ...
  6. #6
    Construction
    Small Construction
    Construction
    Architecture 2013
    Oct 2007
    85
    rotate, orbit, whatever it takes to get a different view of the object, and then I redraw the lines that I need to complete a surface.
    It doesn't cause a recalculation.
    When you have several lines and surfaces, it can be difficult for the program to understand what surface you want to be whole or finished.
    So, I rotate or orbit around, and then there are less lines for the program to see and SU generally figures out that I want to make an area a surface.
    And sometimes, this takes several tries...
    edit: sorry, in my first post, I did make it sound like it happened automatically. It does not.
    Matt
  1. Free 3D CAD software...
    By ReMark in forum Catch All
    Last Post: 25th Feb 2011, 03:50 pm
  2. Free Inventor LT Down Under
    By JD Mather in forum Autodesk Inventor
    Last Post: 22nd Nov 2007, 08:52 pm
  3. Free Download of the new Inventor LT (and free training!)
    By Lynn Allen's Blog in forum AutoCAD RSS Feeds
    Last Post: 13th Jun 2007, 07:31 pm
  4. Free 2D CAD software from UGS
    By f700es in forum Design Software
    Last Post: 15th Dec 2006, 04:01 pm
  5. Free CAD software ?
    By hyposmurf in forum Catch All
    Last Post: 5th Mar 2004, 06:05 pm
