identify multiple co-ordinates
Chanell DP
I need a quicker way to identify the co-ordinates of the stormwater system. Preferably as a list which I can then import into Excel.
We working on the WG27 co-ordinate system imported from Model Maker.
Your help will be greatly appreciated. :(
If you type LIST and select everything you want it will give you all coords, but as far as exporting to Excel, other than copying and pasting I don't know I'm afraid.
I've moved your question to the "Map 3D" section.
... and I moved here the thread from the Beginner's Area. It is enough to have a question asked once in the forum.
Is your stormwater system composed of Civil 3D objects or regular AutoCAD objects? If Civil 3D objects then I don't believe Map will be able to extract that information. If AutoCAD objects then you can perform a Map query on the objects to get the data you need (provided that your objects are blocks or are layered separately from other objects).
