flowerrobot Posted September 12, 2008 Share Posted September 12, 2008 i have automated putting in a leader with certain text this works correct, just the text come in a line so that the only a few words fit in each row(like this) and to fix it all u need to do it drag the box and the text goes back to how it should come out not this would not being a problem if i was doin this by hand, but due to it being automated it screws up the routine, how do you fix this? easy way to see the problem do a qleader, select the ip with mouse, and them from their only use the key board to select every thing, this means that u can not use mtext, and u should see the problem and help would be awesome regards Flower Quote Link to comment Share on other sites More sharing options...
neekcotrack Posted September 15, 2008 Share Posted September 15, 2008 You could always make a leader without the text, then insert mtext at the last point from the leader. Just make sure the mtext is left justified. Quote Link to comment Share on other sites More sharing options...
flowerrobot Posted September 16, 2008 Author Share Posted September 16, 2008 You could always make a leader without the text, then insert mtext at the last point from the leader. Just make sure the mtext is left justified. Yes, That would be a simple solution normally, tho it would be quite harder to do as i have a quite long code just for the point for the leader, and a smallish one dependent on the scale of the dwg for the tail, and hence would cause quite long and complex piece of coding for such a simple product, hence why i was asking to see if i could adjuct the text box, thank you tho, it may well become the way i have to do it Regards Flower Quote Link to comment Share on other sites More sharing options...
Dipali Posted September 16, 2008 Share Posted September 16, 2008 to adjust the text box, i ususally select it & in properties pallette i change the 'defined width' value to very high. and than if i want the text not in one line but lutiline I use enter to go to next line while writing the text. I do not have experince with lisps but thought the method may help you to write yours. Quote Link to comment Share on other sites More sharing options...
