Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2008
    Sep 2008
    5
    Default Change Block Attribute base on Insertion Point
    I have a group of blocks, SCP1, SCP2, and SCP3 that each hold an attribute called panelnumber. These blocks are placed in the drawing automatically in a VB module that takes user input values. These blocks are placed in the drawing and are stacked in a series of columns and rows. The number of columns and rows varies. The panel numbers are sequentially placed with the first block being on column 1, row 1, then column 1 row 2, so from left to right top to bottom. There are times when a block maybe removed and another block added. I am looking for a way to renumber the blocks by selecting them in a window then renumbering them from left to right top to bottom.
    How do I get the insertion point of the blocks?
    Thanks
    Senior Member borgunit's Avatar
    Mechanical 2006
    May 2007
    Ohio USA
    287
    Create a selection set of the blocks and then cycle through each one of them in the selection set ie
    Code:
    For Each acBlk in acSset
        vPts = acBlk.InsertionPoint
    Next acBlk
    You could store the insertion points in an array and then sort them out how you want.
    AutoCAD Mechanical 2006
    XP PRO SP3
    http://mechcad-insider.blogspot.com/
    Forum Newbie
    AutoCAD 2008
    Sep 2008
    5
    Thanks for the reply.
    I am new to array's. I have been able to call the blocks, find the minimum and maximum x and y coordinate. Count the number of columns and rows. I do not know how to define an array and then sort them according to x and y coordinates. Can you point me to an example code snippet that uses arrays? Your help is appreciated.
    Mechanical 2006
    May 2007
    Ohio USA
    287
    Code:
    Dim vPts() as variant '<< an array
    Dim i as integer
    i = 0
        ReDim Preserve vPts(1, i) '<< dimension the array each pass
        vPts(0,i) = acBlk.InsertionPoint(0)
        vPts(1,i) = acBlk.InsertionPoint(1)
        i = i + 1
    Next acBlk
    XP PRO SP3
  5. #5
    Forum Newbie
    AutoCAD 2008
    Sep 2008
    5
    Thanks I will try that.
    I need to sort, by x and y (min to max) then change an attribute tag "panel number" sequentially top to bottom left to right. Blocks are “SCP1”, “SCP2” and “SCP3”
    Any thoughts
  6. #6
    Mechanical 2006
    May 2007
    Ohio USA
    287
    XP PRO SP3
  7. #7
    Forum Newbie
    AutoCAD 2008
    Sep 2008
    5
    Thanks! Just what I was looking for!
  8. #8
    Forum Newbie
    AutoCAD 2008
    Sep 2008
    5
    Borgunit many thanks
    Here is what I finally used.
    This program will search an ACAD drawing for blocks called SCP (SCP* finds SCP1, SCP2, and SCP3). When it finds the block it stores the insertion point of the block into a data array. It then sorts the data array according to the x value then the y value. Once it sorts the data it then calls each block based on the x and y coordinate and finds an attribute value "PANELNUMBER" and sequentially numbers the panels based on the x and y value (x column left to right, y row top to bottom).
    I have to give major credit to a colleague of mine who cleaned my code up to get it to look like this.
    Code:
    Function reNumberPanels()
    Dim myBlock As AcadBlockReference
    Dim oBkRef As AcadBlockReference
    Dim i As Integer, J As Integer, temp As Double
    Dim DArray() As Double
    Dim PanelNumber As Integer
    Dim ssetObj As AcadSelectionSet
    Dim mode As Integer
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    Dim varAttributes As Variant, k As Integer
    Set ssetObj = ThisDrawing.SelectionSets.Add("SSET")
    mode = acSelectionSetAll
    gpCode(0) = 8
    dataValue(0) = "ATTRIB"
    ssetObj.Select mode, , , gpCode, dataValue
    '******** Determine the coordinates for the SCP* blocks and set in Data Array **************'
    Dim ik As Integer
    ik = -1
    For i = 0 To ssetObj.Count - 1
    If TypeOf ssetObj(i) Is AcadBlockReference Then
    Set oBkRef = ssetObj(i)
    If UCase(oBkRef.Name) Like "SCP*" Then
    ik = ik + 1
    ReDim Preserve DArray(1, ik)
    DArray(0, ik) = oBkRef.InsertionPoint(0)
    DArray(1, ik) = oBkRef.InsertionPoint(1)
    End If
    End If
    Next i
    '******** Sort the dtat array by x then y coordinate **************'
    For i = 0 To UBound(DArray, 2) - 1
    For J = i + 1 To UBound(DArray, 2)
    If Round(DArray(0, i), 2) > Round(DArray(0, J), 2) Then
    temp = DArray(0, i)
    DArray(0, i) = DArray(0, J)
    DArray(0, J) = temp
    temp = DArray(1, i)
    DArray(1, i) = DArray(1, J)
    DArray(1, J) = temp
    Else
    If Round(DArray(0, i), 2) = Round(DArray(0, J), 2) Then
    If Round(DArray(1, i), 2) > Round(DArray(1, J), 2) Then
    temp = DArray(0, i)
    DArray(0, J) = temp
    temp = DArray(1, i)
    DArray(1, J) = temp
    End If
    End If
    End If
    Next
    Next
    '******** Search the for the "PANELNUMBER" attribute by Data Array and reset values sequtinally **************'
    If ssetObj.Count > 0 Then ssetObj.Clear
    For J = 0 To UBound(DArray, 2) - 1
    If Round(DArray(0, J), 2) = Round(oBkRef.InsertionPoint(0), 2) And Round(DArray(1, J), 2) = Round(oBkRef.InsertionPoint(1), 2) Then
    varAttributes = oBkRef.GetAttributes
    For k = LBound(varAttributes) To UBound(varAttributes)
    If varAttributes(k).TagString = "PANELNUMBER" Then
    varAttributes(k).TextString = J + 1
    varAttributes(k).Update
    End If
    Next k
    End If
    Next
    End If
    End If
    Next
    ThisDrawing.SelectionSets("SSET").Delete
    End Function
  1. MOVING THE BASE POINT/ INSERTION POINT
    By nwmjdp in forum AutoCAD Beginners' Area
    Last Post: 13th May 2012, 06:44 am
  2. using insertion point in block attribute
    By aamotox in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Feb 2007, 09:07 pm
  3. Change the Block Insertion Point on the Fly
    By CAD-e-Corner in forum AutoCAD RSS Feeds
    Last Post: 5th Sep 2006, 09:14 pm
  4. Get x,y coordinates of blocks insertion point into attribute
    By tpatton10 in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Dec 2005, 02:11 pm
  5. Rotate a Block and Have Base Point Dynamically change
    By Jedidia in forum AutoCAD General
    Last Post: 7th Mar 2005, 10:08 pm
