Results 1 to 9 of 9
    bepcec
    Default calculate 3D polyline area
    Hi all,
    I'm new here.
    Is there a way to calculate a (closed) 3D polyline area ?
    Thanx in advance.
    Ciao.
    Beppe
    Super Member
    AutoCAD 2007
    Aug 2003
    Livingston, Scotland
    995
    do you mean programatically or just by typing the LIST command ?
    ResourceCAD.... the Resource for your CAD Solutions
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,925
    A 3DPOLYLINE doesn't really define the planes needed in order to calculate an area. So in short, no, you can't. -David
    R12 (Dos) - A2K
    bepcec
    Hi hendie and David Bethel,
    thanx for your replies.
    I know : a 3D polyline doesn't define a plane.
    But my question was about how to resolve THAT problem (programatically or not).
    Triangulation ?
    Ciao.
    Beppe
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    1,925
    Beppe,
    I'm afraid you cannot do it. ACAD does not give you enough information.
    Example: Draw a non coplaner 3DFACE. Acad does not speciffy whether points 10, 11 & 12 make a face or use 11, 12 & 13. ( These images are fairly poor representation of this. )
    The same goes with a 3DPOLY. There is simply no way of knowing which edges match up to make the plane. -David
    R12 (Dos) - A2K
  6. #6
    ervine
    As Beppe mentioned, triangulation is a solution here.
    Dono if you have the option, but triangulate the 3dpoly and remove any triangles outside of the polyline.
    Then calculate is using eg the Heron formula [3 3D-line lengths] and add them all. See http://astro.temple.edu/~dhill001/tr...anglearea.html and look for Heron.
    Proof of the formula: http://www.math.umn.edu/~rejto/1151/1151_heron.pdf.
    It depends on how many vertices the polyline got and how they relate to each other. All evenly spread would give best result.
    Esri is using same logic: area of accumulated triangles of a tin: http://arcobjectsonline.esri.com/Arc.../bas3DArea.htm
  7. #7
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    I agree with David Bethel: you need more info to calculate the area of a 3D polyline. Here is a sample:
    There are a lot of possibilities to construct a surface...
    I didn't calculate the areas for these surfaces but probable that are not the same.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  8. #8
    Forum Newbie
    Civil 3D 2012
    Oct 2011
    3
    Hi,
    this is an old post but I hope still up-to-date problem:
    I am also new to Civil 3D and have similar situation - I was thinking if there is a way to quickly know an area of "footprint" of a 3D polyline? I know I could copy it, flatten and there it is, but if I need information as such for numerous p-lynes I will have a lot of extra work...
    Any suggestions?
    Mike
  9. #9
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    In Autodesk Inventor I would simply create a Boundary Patch and Inventor would tell me the area.
    Can you attach your dwg here - perhaps it can now be done with AutoCAD (How complicated is the boundary?)
    (I don't use Civil 3D - but I think it can be done there as this has been a pretty common question).
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
