Results 1 to 10 of 10
    Full Member KnoJa31's Avatar
    Electrical
    KnoJa31's Discipline Details
    Drafter/Administrator
    Electrical
    AutoCAD 2012
    Sep 2008
    Everett,WA
    64
    Default Tool Palettes Export- Help!!!
    HELP!!!!!!!
    I am on a tight time schedule for these tool palettes that i have created. My lead wants a group of all the tool palettes that i have created for all users to use.
    I have exported all of the palettes to a location on the network. I also exported the group to the same location. I had the user redirect the tool palette path in the Options>Files. The problem that i am running into is that when the users are loading up the tool palettes, they have to import each tool palette seperately then add them to a group.
    Is it possible to have the tool palettes in a location on the network and have each of the users import the group only?
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,582
    Quote Originally Posted by KnoJa31 View Post
    HELP!!!!!!!
    No, you will still have to import each Palette one by one, then import the Group. The Group Export only sustains the organization of the Tool Palettes.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Electrical
    Electrical
    AutoCAD 2012
    Sep 2008
    Everett,WA
    64
    That was what i was afraid of!!! Ok, thanks!!
    Senior Member jaylo23's Avatar
    jaylo23's Computer Details
    Windows XP
    Dell Precision 390
    Dual Core Intel(R) Core(TM) 2 CPU
    3.5 GB
    ATI Fire GL V5600
    Dual Viewsonic
    Mechanical
    jaylo23's Discipline Details
    Mechanical Designer
    Mechanical
    AutoCAD 2010
    Sep 2008
    Dayton, OH
    107
    I had to do a similar thing with the tool palletes knoja31 and all i did was copy out the tool pallette folder under my autocad support file to the network and had my cad operators replace it on each of there computers autocad support file. Then i did an group export all under the customize tool pallette dialogue box and had them inport this file in each of there customize tool pallette dialogue box which automatically sorts the groups out.
  5. #5
    Senior Member neekcotrack's Avatar
    MEP 2009
    May 2008
    Florida
    329
    Quote Originally Posted by jaylo23 View Post
    I would do this. It will help i think in the long run. There are .atc files of each tool pallete you make. Put them in a folder called read only because you can right click them and make them read only. Make sure to change your tool palette path to the location of the .atc files on the network.
    As long at then have there seach path to the palletes sourced and organized on there computer. You can just copy and drop new ones everytime there is and update and then will get it if they restart cad if they are already in it.
  6. #6
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,050
    copy the toolpalette folder you've created with all atc files on the network, have the below coding loaded on all machines (if you have a company acaddoc file, just place it in there (make sure you change the path to match yours). you don't want to make them read only, how can you update them. just get IT to remove write access to that folder for everyone except you; that way, you, or whomever chosen for toolpalette upkeep, can make alterations and noone else can change them.
    Code:
      (setq    files        (vla-get-files (vla-get-preferences (vlax-get-acad-object)))
    ;    expaths        (vla-get-ToolPalettePath files)
      (setq newpath (strcat
            "G:\\cadd standards\\Toolpalette
      (vla-put-ToolPalettePath files newpath)
  7. #7
    Super Member MarcoW's Avatar
    MarcoW's Computer Details
    Microsoft Windows 7 Pro 64-bit
    A black one
    Intel Xeon E5520 Quad Core
    8 GB
    NVIDIA Quadro FX 580 - 512MB
    300 GB 10000 RPM
    AutoCAD 2011
    Apr 2009
    The Netherlands
    599
    Quote Originally Posted by alanjt View Post
    Code:
    After searching and not finding what I want to know:
    The system variable "toolpaletepath" is gone in Autocad 2010.
    Am I right?
    I have a routine that changes that path so the toolpalettes will change to.
    Or am I missing something?
    (I know it is an old thread but that is not the point now)
  8. #8
    A black one
    8 GB
    300 GB 10000 RPM
    AutoCAD 2011
    Apr 2009
    The Netherlands
    599
    ... finally I post it, then I find it.
    This is what I was looking for:
    ^C^C*_toolpalettepath "c:";TP;
    (To change to C: as directory)
  9. #9
    Civil 3D 2011
    Apr 2008
    6,050
    Quote Originally Posted by MarcoW View Post
    The above posted code, while sloppy, will do what you need.
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  10. #10
    Full Member
    AutoCAD 2006
    Feb 2011
    48
    Its a good thing the "search" function is working properly....this info is sweet...just what i need!!! thanks guys!!!
  1. Tool Palettes
    By Jeff Podgorski in forum AutoCAD Beginners' Area
    Last Post: 13th Feb 2008, 11:57 pm
  2. Tool Palettes
    By Davina Ware in forum AutoCAD General
    Last Post: 20th Sep 2007, 08:51 am
  3. Old Tool Palettes
    By Rhayes in forum AutoCAD Drawing Management & Output
    Last Post: 21st Aug 2007, 06:42 pm
  4. Network Tool Palettes
    Last Post: 10th May 2007, 07:14 pm
  5. How custom tool button images are created for tool palettes
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 21st Feb 2007, 04:13 am
