second view port can't find the model
b.muqlueen
hey hows it going. i got a problem and its a biggie. i got a duct file. huge(2,000+kb)(so attaching is an issue).
heres the problem. i xrefed the duct drawing(overlay). in ms. i drew my equipment and piping. in the first layout in ps. i dimensioned and text. its a big layout so i need a second layout with match line.
so i did what i normally do. set up ps. to the paper size i need by setting the first layout current.
Problem is when i do mv i cant find my model through pan and zoom. while the model tab is clicked.
i need this printed for tomorro. this is extremely important. please any body who can help please. i can attach the overlay i did if that helps.
6TH FL COORD 2 9-17-08.dwg
Open the file you are xrefing in, while you can see all the information that you expect in MS start the erase command, type All, then type R (remove) and use a window selection to surround the stuff you want to keep, hit enter. Now do a zoom ,extents. Do you see all of your drawing still? If yes, save and close and go back into your other drawing and try again.
