Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Senior Member
    AutoCAD 2007
    Feb 2007
    Brisbane Australia
    455
    Default survey coordinates
    I sometimes have to draw of survey plans
    I can draw this manualy drawing very slow because I am cheaking, double cheaking and cheaking again so I don't make a mistake. They are all realitive and a mistake will make them all wrong
    or I can write this in my menu
    ^C^C_line;0,0;+
    @970.947<233d19'55";+
    @115.625<237d19'25";+
    @128.625<276d38'45";
    If I make a mistake it is easy to edit my menu and run it again
    How do I write this in lisp?
    I'm now a senior member.
    Someone may think that I know what I'm doing. If so, I sure fooled them!
    Senior Member
    AutoCAD 2007
    Feb 2007
    Brisbane Australia
    455
    for 88.057<109d01'25";+
    Id like to write
    88.057
    109
    1
    25
    115.625
    237
    19
    25
    or something like that where the values are sepparate but still close together
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by rookie37 View Post
    ^C^C_line;0,0;+
    i don't understand, you are going to plot lines with the same bearings & distances for multiple occasions (meriting creating a button), or are you just trying to find an easier way to plot lines within autocad? i remember having to draw lines like that @100<N25d19'16"W, i'm so glad LDD has it's own line by bearing option.
    Senior Member
    AutoCAD 2007
    Feb 2007
    Brisbane Australia
    455
    I'm trying to find an easier way to plot lines. I also want to write down those commands. It won't be for multiple occasions.
    Currently, I change my menu often which is a hassle and that it why I'd rather do it in a lisp program
    I'm not familure with LDD. Is it a tool in Autocad? It may work but only if I can write down the coordinates I draw
  5. #5
    Full Member hay123's Avatar
    Map 3D 2010
    Aug 2008
    Australia
    67
    Hi,
    I am a surevy draftsperson, and have to draw lines at different bearings all the time. For me it's second nature a bit to type a line at - @10<4d12'45" (enter) @12<120d8'16"
    I was a bit confused when you said you have to change your "menu" all the time, can you explain what you mean?
    Also, I find mistakes are usually picked up at the end. Usually I would type bearings and distances when creating lot boundaries, and if the boundary dose not close at the end, than I have made a mistake somewhere, and just do a quick check via properties box to see whats wrong.
    Sorry I can't be more helpful. Will be watching to see if anyone comes up with something clever.
  6. #6
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Try this
    Code:
    ;Tip1741:  BD.LSP           Bearing/Distance lines         (c)2001, Joon Hong  $50 Bonus Winner
    (defun C:BD  ()
      (setvar "cmdecho" 0)
      (initget 1)
      (setq PT (getpoint "\nPick a starting point: "))
      (initget 1 "NE NW SE SW")
      (setq BR (getkword "\nPick bearing (NE/NW/SE/SW): "))
      (setq OPT (strcase BR))
      (initget 1)
      (setq LEN (getreal "\nType the length: "))
      (setq DEG (getstring "\nType the degree: ")
            minx (getstring "\nType the minute: ")
            SEC (getstring "\nType the second: "))
      (if (= DEG "")
        (setq DEG "0"))
      (if (= minx "")
        (setq minx "0"))
      (if (= SEC "")
        (setq SEC "0"))
      (cond ((= "SW" OPT)
             (setvar "angbase" (cvunit 270 "degree" "radian"))
             (setvar "angdir" 1))
            ((= "SE" OPT)
             (setvar "angdir" 0))
            ((= "NW" OPT)
             (setvar "angbase" (cvunit 90 "degree" "radian"))
            ((= "NE" OPT)
             (setvar "angdir" 1)))
      (command "line" PT (strcat "@" (rtos LEN) "<" DEG "d" minx "'" SEC "\"") "")
      (setvar "angbase" 0)
      (setvar "angdir" 0)
      (setvar "cmdecho" 1)
      (princ))
    (princ "\nType 'BD' to draw lines with bearings")
    Senior Member
    AutoCAD 2007
    Feb 2007
    Brisbane Australia
    455
    Thank you lpseifert
    That program is a huge timesaver!
    However, I still don't know how to set up acad for bearing distance
    I can change the setup but there are many options to choose
    rotation
    clockwise?
    direction
    n?
    e?
    s?
    w?
    My ignorance in this reminds me of my Navy days. When I was still very green, I was sent all over the ship asking to borrow some relative bearing grease.
  8. #8
    Map 3D 2010
    Aug 2008
    Australia
    67
    I type 'units' then change the 'angle' to Deg/Min/Sec, and direction to North 270 (which makes 0deg at top of page or 12:00 on a clock)
  9. #9
    Super Member nocturne00's Avatar
    nocturne00's Computer Details
    Windows Vista SP2
    Dell Studio XPS
    Intel(R) Core(TM)2 Duo CPU P8600
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    769
    Quote Originally Posted by lpseifert View Post
    Try this
    Code:
    (defun C:BD  ()
      (initget 1)
      (initget 1)
      (if (= DEG "")
        (setq DEG "0"))
      (if (= minx "")
        (setq minx "0"))
      (if (= SEC "")
        (setq SEC "0"))
      (cond ((= "SW" OPT)
            ((= "SE" OPT)
            ((= "NW" OPT)
            ((= "NE" OPT)
      (setvar "angdir" 0)
      (princ))
    Sorry, couldnt help to grab this, been lookin for something like this for a while now also, just posting to consent.
    thanks
    ....always perform Beyond what is expected.
  10. #10
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    rotation
    clockwise?
    direction
    n?
    e?
    s?
    w?
    In what format is the survey data? Surveyor's Units (e.g. 110' N45d30'30"E)?
    Post an example of the data you need to input, it would help in telling how to set up your units.
  1. Survey Help
    By stephenward in forum AutoCAD General
    Last Post: 15th Jun 2008, 05:10 pm
  2. Replies: 1
    Last Post: 15th Feb 2008, 07:21 am
  3. Survey
    By bauvi727 in forum AutoCAD Drawing Management & Output
    Last Post: 6th Nov 2006, 03:07 pm
  4. Survey coordinates
    By GW in forum AutoCAD Beginners' Area
    Last Post: 20th Feb 2006, 01:27 pm
