Results 1 to 6 of 6
    Junior Member
    not specified
    Oct 2004
    NY
    21
    Default Plot All Layout Tabs
    Hi all,
    Can we plot in AutoCad 2005 All Layout Tabs.
    I know we can do it in AutoCad 2004.
    Tank you
    Full Member
    Architecture 2009
    Jan 2005
    Chichester England
    65
    Under the file menue use the publish command, it will list all of the current layout tags. You can print all or some. You can also import other drawings into what is in effect a batch plot.
    "If I have seen further it is by standing on the shoulders of Giants." --Isaac Newton
    ADT 2009
    Junior Member
    not specified
    Oct 2004
    NY
    21
    42,
    I appreciate your help.
    thank you very much.
    Forum Newbie
    Fett2oo5's Computer Details
    Dual monitors
    Multi-disciplinary
    Fett2oo5's Discipline Details
    Elec/Mech/Struct Engineering and Systems Development
    Multi-disciplinary
    AutoCAD 2013
    Nov 2011
    Houston, TX
    4
    This is great! Thank you! (using autocad 2012) We don't normally use layouts, currently I have a project which makes it necessary. Not being familiar with layouts this helps a lot. Thanks for this tip!
  5. #5
    Full Member hcostanzo's Avatar
    hcostanzo's Computer Details
    Windows 7
    Civil
    hcostanzo's Discipline Details
    Civil
    worked in the Structural field for 5.5 years, now learning the ins and outs of civil work
    Civil 3D 2013
    Sep 2012
    Colorado, USA
    25
    I never knew about the publish command. This is a huge help, thank you!
  6. #6
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    You can do the equivalent to publish also via lisp etc nice thing is just pick 1 option on menu and all are printed, pdf A3colour A3Mono A1 Tiffs, also did a plot all title blocks in modelpsace no matter where they are. If you think you want to go this way there are numerous posts here and very simple to follow use search. They should work with 2005.
