Xref into layout/paper space
PJOSS
Paperspace Objects Can Not Be Imported To The Drawings Thru Xref As Far As I Know (correct Me Someone If I Am Wrong).
What We Normally Do Is We Have A Title Block Drawing In Model Space At 1:1. And Save That Drawing. Than We Open The Drawing We Are Working On Go To Paper Tab & Use 'xref' To Bring In The Titleblock Here In Papersapce.
No that's not it. My theory is that the ability to Xref attach a drawing, so that it's Paper space layout appears in the paper space layout of the parent drawing, is not possible in Autocad LT.
I'm being told from other sources that this does work and I suspect that they are either using the full version of Autocad or more likley one of Autodesks "vertical" solution software packages such as Architectural version.
I would appreciate help from you or anyone who can confirm this.
Many thanks.
  • 1 year later...
