so this isn't actually MTEXT or DTEXT, but some sort of label is it?
or is it a dimension?
I'm trying to label the boundary of a property. It has straight lines on sides and curves on top and bottom. i managed to change the style of the text the way I want it (radius and length above, delta below). The problem i have is that I don't know how to change the height of the text. The option under "Text properties" in "Edit Label styles" is shaded ( I cannot change it).
Thanks for help
Find your newbest friend
at
Rain Rescue
If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
Sounds like you're using Land Desktop. If my memory serves me correctly the text size is controlled by the scale of the drawing. Check the scale in your drawing settings.
"Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
flickr | work | blog | creed
rustysilo's tips & tutorials
this is all by memory...
go to Format > Text......create a new text style that is the same as what you already have only larger. Then change that label to that text style...
let me know if it worked
Failure is a dress rehearsal for success.
AutoCAD Land Development Desktop (2000, 2005 & 2006 )
Civil 3D 2008
