Bob, the problem isnt that it wont come up, the problem is that when it does Try to come up there is an error stating there are no pallets. I had this same problem with my first install of 2010 C3D. I agree with doing the repair install however, if that does not work i suggest doing a complete "clean" uninstall then reinstall it. make sure you look up the instructions on how to do a clean uninstall with your version of cad, if you dont follow the directions in which folders to delete after the uninstall then the reinstall could have the same issues as before, maybe more.
after repair fails (but I think it shouldn't, as it worked for me just fine) then after that you can do a re-install.
