Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2006
    Sep 2008
    1
    Default layer properties manager does not open
    I cant figure out what happened but the layer properties manager box does not open any more??
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,022
    Not open at all? How about via the command line? Does that not work as well?
    Forum Newbie
    banana's Computer Details
    XP Pro
    AutoCAD 2006
    Nov 2008
    Vancouver
    7
    Default Layer Properties Manager doesn't open -ACAD 2006-
    I'm experiencing the same problem as the OP.
    Layer Properties Manager will not open. ACAD will sit there, seemingly loading the LPM, but nothing happens. I eventually have to 'Esc' to continue.
    Get the same result from comand line "_layer" and clicking on the LPM button on the "Layers" toolbar.
    Any help would be great!
    Cheers.
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Maybe it's off screen...
    Start _layer, hit Alt+Spacebar, then M, then use your arrow keys to bring it back on screen (you may want to try it with a visible window to get the gist).
    or...
    Set a higher display resolution in Windows so you can see it.
  5. #5
    Forum Newbie
    XP Pro
    AutoCAD 2006
    Nov 2008
    Vancouver
    7
    Default *solved*
    Brilliant!
    The LPM box was way off screen. Thanks lpseifert!
    For anyone else that may have similar problem: I could not move the window into view using "Alt+Spacebar" then "m". However, "Alt+Spacebar" and then "s" will resize the window. just hold down a direction key (in my case I held the left arrow) and the window will appear.
    Thanks again lpseifert.
    Cheers!
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,022
    Nice work lpseifert.
  7. #7
    Forum Newbie
    AutoCAD 2006
    Dec 2008
    3
    Thanks so much...thought I was going crazy when several of my dialogue boxes weren't showing up!
  8. #8
    Forum Newbie
    AutoCAD 2007
    Nov 2008
    1
    Thank you also for the tip. Problem fixed. It was opening off screen.
  9. #9
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    I'll just add a note for the users here that use non-English versions of Windows programs - since this is a Windows fix and will work with any Windows application.
    In the combo alt+spacebar+M, the M stands for MOVE - so if the combo doesn't work for you, try a combo where the M is replaced with your native word for MOVE. I (Swedish) use F
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
  10. #10
    Forum Newbie
    AutoCAD 2007
    Jul 2012
    1
    Default Thanks to lpseifert
    Quote Originally Posted by lpseifert View Post
    or...
    You saved my very precious time. Thank you
  1. Layer properties manager
    By jw in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jul 2009, 09:50 pm
  2. Properties Manager does not open...??
    By Julie@Integra in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th May 2008, 02:46 am
  3. Layer Properties Manager
    By ralph in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 1st May 2008, 03:55 am
  4. Layer properties Manager Box
    By fpdawg in forum AutoCAD Drawing Management & Output
    Last Post: 28th Sep 2007, 04:34 pm
  5. Layer Properties Manager
    By odnamra in forum AutoCAD Drawing Management & Output
    Last Post: 1st May 2007, 04:29 pm
