nicnicman Posted October 5, 2008 Share Posted October 5, 2008 Hi everyone, I am working on a floorplan and I'm having difficulties with LTScale. The attached drawing has an overall ltscale of 20. The hidden lines along the top of the drawing have a ltscale of 5.5 which I set using the properties box. It took me a while to get the center(magenta) and hidden lines to look right but I finally got it using these settings. The problem is when I switch to paperspace the lineweights are all screwed up. They all appear solid. Any help and suggestions are welcome. Thanks nicnicman Quote Link to comment Share on other sites More sharing options...
BOB'27T Posted October 5, 2008 Share Posted October 5, 2008 Check your PSLTSCALE setting. That way the lineweights will stay the same in paper and model space. Quote Link to comment Share on other sites More sharing options...
nicnicman Posted October 5, 2008 Author Share Posted October 5, 2008 It's set to one. Is this correct? Quote Link to comment Share on other sites More sharing options...
nocturne00 Posted October 5, 2008 Share Posted October 5, 2008 set it to 0 Quote Link to comment Share on other sites More sharing options...
nicnicman Posted October 5, 2008 Author Share Posted October 5, 2008 Thanks a lot. This worked great! Quote Link to comment Share on other sites More sharing options...
Teeds Posted October 6, 2008 Share Posted October 6, 2008 This is the kind of oblique stuff that can drive a person nuts. I created a fixstuff.lsp file that I put it all in. I run it once on every drawing file and they all act the same then. All I have to do is set the dimscale of the file and the lisp does the rest. Quote Link to comment Share on other sites More sharing options...
