Results 1 to 6 of 6
    Super Member
    AutoCAD LT 2009
    Sep 2008
    500
    Default Fatal Error, Heap Error
    Any way to fix the autocad file once you get a fatal error? I can't do an audit because it won't open, and a drawing recovery doesn't fix the file. When I got the fatal error, I did NOT save the file. I was told not to save the file when this happens.
    Any suggestions?
    Senior Member BOB'27T's Avatar
    BOB'27T's Computer Details
    Dell Precision 690
    Dual 21" Dell
    Civil 3D 2009
    Sep 2007
    Tavares,Florida
    416
    There should still be a .tmp file on your server. You can find it and rename it to a dwg. Hope this will help.
    "Those Who Pay Attention Will Be Rewarded"
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,471
    Heap error? Really? Haven't seen that since my AutoCAD on DOS days.
    Do you have a .bak file of the drawing? You could rename it to .dwg and at least save some of your work.
    When I've had a fatal error I've elected to save the file. Most times you can't tell the difference with the exception of the loss of the most recent work done to it.
    Senior Member sab423's Avatar
    sab423's Computer Details
    Windows XP
    AutoCAD 2009
    Oct 2004
    Maryland, United States
    130
    You can also look to see if there was a AutoSave file created the file extension is *.sv$. If there is a autosave file just rename the file extension to .dwg.
    Good luck.
  5. #5
    Super Member
    AutoCAD LT 2009
    Sep 2008
    500
    Thanks to all. Especially on the quick response. I guess I knew all along that renaming another file extension, .bak, .tmp, .sv$, etc. was the only way. I was taught NOT to save when you get the Fatal Error, but I think I'll try it the other way next time.
    Again, thanks to all.
    I just thought of something. What if I rename the .bak file and bring it up and it too gets a fatal error?
    I just did a rename on the backup file, opened it, now I get an Internal Error. The drawing never got to the point where I see anything on the screen.
    During the drawing recovery. I got this:
    ACIS error -1073741819:
    Access Violation.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,471
    Just a correction. AutoCAD does not use the .tmp file type for either backups or for temporary files.
  1. fatal error (ARX)
    By The Courage Dog in forum AutoCAD Drawing Management & Output
    Last Post: 5th Aug 2008, 05:38 am
  2. Fatal Error
    By Nick@TE-Direct in forum AutoCAD Drawing Management & Output
    Last Post: 9th Oct 2007, 04:00 pm
  3. fatal error dbx cas 4
    By dismantle in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Jul 2007, 07:20 pm
  4. fatal error
    By tpmiller in forum AutoCAD Drawing Management & Output
    Last Post: 20th Sep 2006, 09:17 pm
  5. Fatal Error
    By chance in forum AutoCAD Drawing Management & Output
    Last Post: 11th Sep 2006, 01:13 pm
