Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    Senior Member
    Architectural
    svorgodne's Discipline Details
    Architect. Lisp developer
    Architectural
    AutoCAD 2013
    May 2007
    Vienna, Austria
    155
    I had the same problem and I found out the xref I cannot detach is also a nested block in another block inside. I found it deleting all entities from the drawing until I found the nested block and of course purging the block. then make the block again changing the name from the nested block in the original block and reinserting. Then the xref can be purged.
    This was my case
  2. #12
    Forum Newbie
    P&ID 2014
    Jul 2014
    6
    Quote Originally Posted by Tiger View Post
    Or a Audit will do the trick if Purge is not enough.
    This did the trick for me. Autit and then Purge. Thanks!
    Edit : Did work only in one case, another drawing still unable to detach. But still 1/2 is a good rate
  3. #13
    Forum Newbie
    Landscape
    MikeS80's Discipline Details
    Landscape Architecture
    Landscape
    AutoCAD 2015
    Sep 2014
    California, USA
    1
    Default This helped
    Quote Originally Posted by bjolma View Post
    I inadvertently attached an xref while in paper space. After it didn't show up in model space (gee, I wonder why), I reloaded it again; when I went to detach it, the above-referenced error message was generated. QSELECT didn't pick it up, but I eventually went to the layout tab containing the xref, zoomed extents, and there it was. I deleted it, and was then able to detach. I'm probably the only one boneheaded enough to make that sort of error, but thought I'd throw it out there.
    Whatever I did, Bjolma, your suggestion sent me down the right track. Maybe I, like you, screwed up and xrefed into paperspace, or something.
    I went through each of my layout tabs and deleted any that I didn't need. I also zoom/extends every remaining layout, and deleted anything unnecessary, including any dots (in case the Xref was tiny).
    I then, on a hunch, went to my xref manager while in paperspace and this time WAS ABLE to delete my problematic Xref!
    Good work, gang! We solved the mystery!
  1. DETACH Unreferenced Xref
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jul 2015, 03:41 pm
  2. Need help on my Detach/Audit/Bind/Purge code
    By JeepMaster in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Aug 2011, 11:36 am
  3. Xref help
    By 010101 in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jul 2007, 10:44 am
  4. xrefs driving me mad! Can't detach
    By Vigilante in forum AutoCAD Drawing Management & Output
    Last Post: 16th Mar 2007, 03:13 pm
  5. Layer states don't transfer from an Xref of an Xref....
    By Dave-CSMW in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2006, 06:02 pm
