Results 1 to 6 of 6
    Forum Newbie
    Architecture 2009
    Oct 2008
    3
    Default Snap on intelligent objects
    For some reason my settings have been changed and I cannot get my snap to work on doors, walls, or windows. It only allows me to snap to the base line for the walls and no where on doors or windows. I used to be able to snap on all corners of the doors and windows and any face of the wall. It's really frustrating! I know it's got to be some setting, but I can't find it. Please help!
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    what are your osnaps set to be?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
    Forum Newbie
    Architecture 2009
    Oct 2008
    3
    I've played around with checking them all on or off. I'm not sure if that's what your asking or not. The problem is that it won't selected the endpoint, midpoint or perpendicular of any door, wall or window. It will also only select the perpendicular of only one side of a wall.
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    that sounds rather annoying!
    There's probably a SETVAR that's been adjusted somewhere along the line, but unfortunately I've no idea which it would be
  5. #5
    Forum Newbie
    Architecture 2009
    Oct 2008
    3
    hmmm. do you know how to reset the settings so that possibly what ever had been changed will restore itself back to normal?
  6. #6
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    Sounds like you are using ADT rather than plain autocad. Go into options and look at the tabs to the far right at the top. One of those will let you filter in or out the intelligent objects you are having trouble with. There is probably a command to type to bring it up as well, but I don't have ADT to try it.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  1. End Snap
    By Simple153 in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Aug 2007, 02:04 pm
  2. snap ang
    By am_sinha in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jun 2006, 11:04 am
  3. Can't snap to hatch objects in 2005
    By CADTutor in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jan 2005, 01:42 pm
