Yes, unless the folder structure is locked down (i.e. made read only for the masses, with only one user able to alter them) then any changes made will affect all users.
I have a question regarding globalizing the Tool Palettes. If I set this up as a networked file directory in the Tool Palettes File Locations path in the Files tab, and someone makes any changes to the Tool Palettes on their seat of AutoCAD, will they change the Tool Palettes across the network as well? Would I need to set up some type of Write restrictions with my I.T. Administrator for all the other guys using AutoCAD? Thanks in advance.![]()
Tannar Frampton | Facilities Engineering | Revit 2013
Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
Life's constantly changing - keep up or get left behind
This is true. I have set that up in a few of our offices here on the west coast. We have roughly about 13 different palette structures from our Company standards to client standards. These are locked down with folder permissions.
We did find that creating one location for multiple offices did not work. Well it did actually but it caused AutoCAD to slow down so much that it became unusable because of the networked connections.
Hope this helps
In my experience - you should only have one person with WRITE access to the tool palettes. If more than one person have WRITE access, then the last one out wins.
I sat down with my I.T. Administrator today... he said he's perfectly fine with this setup. We are going to sit down when we have time and brainstorm which server and what type of directory hierarchy we're going to use, because I want to utilize this not only with the Tool Palettes but also with the *.LSP file like you state on your Blog, so I can further take advantage of efficiency in the office.
I do wonder though, what are some other common things I can utilize in a network environment using AutoCAD? Anyone?
And thanks for all the help from everyone.![]()
Ah yes... good point. Didn't even think about the Pen Tables.
Cui and lin files, blocks, all kinds of programming (i.e. lsp scr dvb arx dll) ; pretty much everything you wish to be standardised should be on a sharable network resource; and its location(s) should be set up in the autocad search paths
All of the above....
The really cool part is once you have established your network location as the the TOP support directory, anything you add to that location will be used (like "acad.pgp", "acad.lsp", "acaddoc.lsp", sdsk.dfm file for LDT, "acad.fmp", etc.) and in the same notion, if you remove it - AutoCAD will revert to the next copy it finds, which is usually the local one (C:\Documents and Settings\username\etc.)
Well then let me ask this then: I was thinking about setting up the Network Directory with the same hierarchy as Autodesk does it (or maybe as close as I can get). So, can if I add in the root directory, will it pick up the PGP and LSP files, as well as the rest that are in sub directories or do I need to map out their paths individually?
