Results 1 to 6 of 6
Thread: editing text
    Forum Newbie
    Architecture 2007
    Apr 2008
    8
    Default editing text
    hi,
    double clicking any sort of text isn't working -
    don't know exactly how this happened, it was working fine when i first started up this morning -
    have i messed with a setting somewhere?
    Super Member nocturne00's Avatar
    nocturne00's Computer Details
    Windows Vista SP2
    Dell Studio XPS
    Intel(R) Core(TM)2 Duo CPU P8600
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    759
    check your selection settings, Options> Selection> Selection Mode> Check noun/Verb Selection
    ....always perform Beyond what is expected.
    Forum Newbie
    Architecture 2007
    Apr 2008
    8
    yep did that double click editing setting was on.
    sussed it out in the end - other commands weren't working properly either, looking through the system variables "SETVAR" discovered that "PICKFIRST" was off.
    still - don't know how that happened.
    Windows Vista SP2
    Dell Studio XPS
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    759
    Quote Originally Posted by the_phil View Post
    that would be the same as the non/verb selection setting under option.
    this commonly happens when you are using the MVSETUP command, when aligning or rotating viewports, it resets your ONSNAP and PICKFIRST variable (but only until the command is done).
    If you terminate the command prematurely (ESC), changes done by the MVSETUP command will retain, thus your PICKFIRST variable, ONSNAP settings are screwed up
  5. #5
    Forum Newbie
    Architecture 2007
    Apr 2008
    8
    that's it !!
    i was using mvsetup - i aligned rotating but put the wrong angle in for the rotate and just escaped from the command
    genius
  6. #6
    Senior Member bonehead411's Avatar
    bonehead411's Computer Details
    XP Pro 2002 SP3
    HP xw6400 Workstation
    Intel Xeon E5320 @ 1.86 GHz Quad Core
    3 GB RAM
    NVIDIA Quadro FX 1500
    HP LP2465
    AutoCAD LT 2011
    Jan 2007
    Beverley, East Yorkshire, England
    219
    Genius indeed.
    LT 2005 doesn't have the MVSETUP function, but I'll try and retain this little nugget in case we ever upgrade to full AutoCAD.
  1. Text editing box is off-screen
    By SteveDevil in forum AutoCAD General
    Last Post: 11th Sep 2008, 03:26 pm
  2. my text dissapers when editing
    By cadclutze in forum AutoCAD General
    Last Post: 11th Jun 2008, 03:24 pm
  3. Editing Text
    By Leroy Jenkins in forum AutoCAD General
    Last Post: 24th Oct 2007, 06:15 pm
  4. Editing text..
    By matt4 in forum AutoCAD General
    Last Post: 24th Jun 2007, 09:21 pm
  5. text editing
    By Jamalama in forum AutoCAD Drawing Management & Output
    Last Post: 11th Sep 2006, 08:28 pm
