Do you mean move, as in by picking a grip point and dragging ?
If so, I have yet to find a variable that will grab all entities contained within an annotative object. If you are using the real move command, they all should move together, however.
Hi guys,
I've got a bunch of annotative dims that I need to move a bit, I have them set to both 1:20 and 1:50 and it's the 1:50 that I see in Model Space. The problem I have is that when I grab a dimension and pull it a bit, I only move the 1:50-version of it. The 1:20 stays where it is. I'm guessing it's a variable (most things are after all) - anyone know how to fix it??
Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
at the moment in one's personal UCS.
Go to PLAN view instead. - Dadgad
Life's constantly changing - keep up or get left behind
A yes, the gripping-and-dragging-move version. Damn... I was hoping on you Bluey![]()
The only thing I have found is to set SELECTIONANNODISPLAY to 1; and move one of the annotations; change your CANNOSCALE to whichever scaled version you wish to move next, then drag the relevant grip to your desired location.
PITA I know, but at the moment, I don't have the knowledge for a more robust method.
yeah.. I remove all other annotations and move it and then add annotative scales when needed...
